查看: 1273|回复: 9
4#6S
发表于 2010-3-20 00:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
The rumours have been around for a while, now we have the first picture of the new 3-axis gyroscope RX from Walkera. As per nanoheli.net the flybarless version of the 4#6 will be called 4#6S. A flybarless 4G6 is said to be in the making too.
Fits into Walkera’s platform strategy
This development fits into the Walkera’s platform strategy, in which several models are based on mostly compatible components. The collective pitch 4G6 and fixed pitch 4#6 of FP based on largely interchangeable components. For the flybarless versions merely a new rotor head and receiver will be necessary.
Megatrend flybarless
It looks like the flybarless trend is finally moving into the sub-micro area. We will see if Walkera’s 3-axis sensor RX will deliver what is expected. Besides the quality of the sensors, the software will probably be the deciding point. Whether there will be corresponding update options – we have to wait and see.
The mysterious 5th servo port
It is also interesting that there are 5 servo ports seen on the RX2433 – for the fixed-pitch 4#6 however, only 4 servo ports needed. So what’s up with the 5th port? Is it a programming adapter or is this RX also a prototype for a CP version with the required 5 servo ports?
 楼主| 发表于 2010-3-20 00:34 | 只看该作者
谁给翻译一下?:em00:
 楼主| 发表于 2010-3-20 00:53 | 只看该作者
4#6S会是八通道小电直吗?:em22:
发表于 2010-3-20 01:18 | 只看该作者
这哥们儿真执着,:em15:
你就自己想想,它会是八通道的吗?你真的不能给自己这个答 案?
发表于 2010-3-20 01:22 | 只看该作者
硕士看不懂英文?
简单说就是4#6s,无副翼系统,新的旋头和整合3轴传感器的接受系统。
比较奇怪的是,rx2433接收系统有5个伺服通道,理论上定螺距的4#6只需要4个伺服通道,现在还不能确定,这个第5通道是个编程接口还是说rx2433是一个兼容5伺服系统的通用接收
 楼主| 发表于 2010-3-20 01:26 | 只看该作者
4#6S会是3舵机斜盘尾桨定距?:em22:
发表于 2010-3-20 01:33 | 只看该作者
你能不能先去新手区看点科普贴之后,再提问?
发表于 2010-3-20 12:14 | 只看该作者
想表达什么
发表于 2010-3-20 20:19 | 只看该作者
不知道2801控是否还支持此机机:em22:
发表于 2010-4-6 21:00 | 只看该作者
是什么意思啊?
