查看: 1607|回复: 17
FMA direct新品充电器即将面世,各位有何高见?
发表于 2010-4-16 10:48 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
性能如下:For Battery types:Lithium Polymer (1s to 8s balanced, 1s to 2s unbalanced), Lithium Ion (1s to 8s balanced, 1s to 2s unbalanced), Lithium Manganese (1s to 8s balanced, 1s to 2s unbalanced), A123 (LiFePO4) (1s to 8s balanced, 1s to 9s unbalanced), NiCd (1s to 21s), NiMH (1s to 21s), 6v, 12v, 24v Lead Acid batteries (Flooded, Gel, AGM, SLA)
Pack capacity:20 mAh to 360Ah
Input voltage:10-32VDC, reverse polarity protected
Input current:1A to 50A, software limited
Power conversion:Synchronous DC/DC converter, supports multiple switcher frequencies of 31.25 kHz, 62.5 kHz, 125 kHz; user selectable by preset, 85% to 93% efficiency depending on output current
Output battery charge current:Adjustable range 10mA to 30A, limited by 50A input current*
Output battery discharge current:Internal discharge 10mA to 10A, 100W max Regenerative discharge 10mA to 30A, 1000W max**
Continuous max output power:516W @ +12VDC input, 1008W @ +24VDC
Cell balancing:Resolution 78uV (16 bit) for 1s-8s Li or A123 (LiFePO4) balanced charging
Voltage calibration:Cell voltage measurements are factory calibrated to a standard traceable to NIST; calibration is to +/- 6 mV
Current calibration:Charge current is factory calibrated on a 4A standard; calibration is to +/- 1mA
Measurement accuracy:
Voltage resolution:78uV (16 bit)
Voltage tolerance:+/- 6mV
Charge current:+/- 1%
Capacity added to pack:+/- 1%
Percent capacity (“Fuel”):+/- 5% (with accurate fuel table defined for battery being charged)
Serial data output:19.2kbps, 8 bits, 1 start bit, 1 stop bit, no parity
Data integrity:Checksum, CRC checking
Cooling fans:Twin, 13 CFM, 50mm diameter
Heat sink:Internal 200W aluminum, thin finned
Output battery connector:“Cellpro” compatible, JST PA series, 9 position
LCD:2 line, 16 character, light grey/blue backlit
Footnotes:*Please note, for safety reasons, available charger current may be limited for certain battery types and/or charging modes, e.g., non-balanced charge of Li
**Please check bullet number 8 in the section titled “Major Features” below for a detailed description of Regenerative Discharge
如果高倍率充电的电池(如5c以上)面世,各位手上现有的充电器就会捉襟见肘了,但是淘宝上的定价也很可观,要两千多大元,不知值不值。
发表于 2010-4-16 12:36 | 只看该作者
已经买了,等货中。
发表于 2010-4-16 13:10 | 只看该作者
楼上米人~~~~~~~~~
发表于 2010-4-16 14:29 | 只看该作者
实属无奈。俺的船一次跑 6S 5Ah x 6块:em17: ,没有其它充电器能在外场喂饱它们。
发表于 2010-4-16 15:15 | 只看该作者
要在中 国卖的话 请至少给个中文的说明! 看不懂!我是文盲!!
 楼主| 发表于 2010-4-16 15:59 | 只看该作者
俺也有苦衷啊......
手上几台充电器,更不上需求,也正在考虑购买这个可恨的家伙......
发表于 2010-4-16 16:12 | 只看该作者
要2千多,没有那个720划算啊
发表于 2010-4-16 17:22 | 只看该作者
哇~30A啊?那充电时车就要着着了吧~
头像被屏蔽
发表于 2010-4-16 17:28 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2010-4-16 18:09 | 只看该作者
楼上,咋不早说涅...... 上次您说是600W,所以投了FMA.:em17: ......早知有国货何必买鬼子东西..... 可否PM个价格范围? 谢啦。
发表于 2010-4-16 18:36 | 只看该作者
原帖由 starmoon 于 2010-4-16 16:12 发表
要2千多,没有那个720划算啊
怎么得出结论的? 可否说说看?
俺是这么算的:
FMA PowerLab8: $240/1008W =  $0.238/W
Hyperion 0720:   $150/250W =  $0.6/W
哪个划算些?:loveliness:  似乎差距还不是一星半点。
发表于 2010-4-16 22:29 | 只看该作者
原帖由 junsi 于 2010-4-16 17:28 发表
我公司的iCharger3010B(10串/30A/1000W)也即将上市销售了!模友有多一个的选择了。http://www.jun-si.com/ProductShow.asp?ID=98
完善功能的同时 能优化一下外观必定大卖   玩模型重心情的人太多了 我就是典型...
发表于 2010-4-17 01:10 | 只看该作者
原帖由 法拉利599GTB 于 2010-4-16 09:29 发表
有同感!
发表于 2010-4-18 04:07 | 只看该作者
希望国货能争口气~
发表于 2010-4-18 04:44 | 只看该作者
看上去不错
 楼主| 发表于 2010-4-19 08:46 | 只看该作者
原帖由 Himalaya 于 2010-4-16 12:36 发表
已经买了,等货中。
是在淘宝上的“魔幻天堂”买的吗?我也准备入手了。
发表于 2010-4-20 00:47 | 只看该作者
原帖由 jmcjq 于 2010-4-18 19:46 发表
fma的第一批货早卖完了。我二月定的货,现在还没拿到。现在在美国订货也要等到6月中旬。不知道国内的卖家怎么卖的。
发表于 2010-4-20 12:53 | 只看该作者
楼上。所谓“卖完了”是指预订一空。货还没人拿到,除了FMA自己和它的一小撮 Beta tester.
如果厂家不食言,第一批预定的5月拿到货,第二批如你所言,6月中旬。:em24:
