查看: 1393|回复: 2
HUDY廉价版新工具
发表于 2004-2-20 22:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
工具咀和以前一样同是"弹簧钢",只是換了用优质胶料做把手。
HUDY profiTOOLS are available in these sizes:
# 111549-Allen Wrench + Repl. Tip 1.5 x 120 mm
# 112049-Allen Wrench + Repl. Tip 2.0 x 120 mm
# 112549-Allen Wrench + Repl. Tip 2.5 x 120 mm
# 113049-Allen Wrench + Repl. Tip 3.0 x 120 mm
# 125049-Allen Wrench + Repl. Tip .050 x 120 mm
# 126349-Allen Wrench + Repl. Tip .063 x 120 mm (1/16”)
# 127849-Allen Wrench + Repl. Tip .078 x 120 mm (5/64”)
# 129349-Allen Wrench + Repl. Tip .093 x 120 mm (3/32”)
# 153059-Slotted Screwdriver 3.0 x 150 mm - SPC
# 154059-Slotted Screwdriver 4.0 mm - for Engine Adjust. - SPC
# 155059-Slotted Screwdriver 5.0 x 150 mm - SPC
# 155809-Slotted Screwdriver - for Engine Head - SPC
# 163549-Phillips Screwdriver 3.5 x 120 mm
# 164049-Phillips Screwdriver 4.0 x 120 mm
# 165049-Phillips Screwdriver 5.0 x 120 mm
# 165849-Phillips Screwdriver 5.8 x 120 mm
点击查看详情
发表于 2004-2-20 22:51 | 只看该作者
HUDY廉价版新工具
报价
发表于 2004-2-21 03:11 | 只看该作者
HUDY廉价版新工具
58一把~
