查看: 3896|回复: 19
KDE 9000W + Align700 = ???
发表于 2010-4-28 00:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近刚刚被蝎子的50**刺激到, 结果发现这还不算什么,这才是Ultimate,现在的电力设备一个比一个变态
CONVERSION KIT:KDE Direct T700N E-Conversion LXKit
MOTOR: KDE Direct 1917H/1Y-N42 S2 HP Brushless
ESC: Castle Creations Phoenix ICE HV160, v3.2 Firmware
BEC: Western Robotics Hercules Super BEC (set to 8.4V)
LiPos: Outrage NRG 35C, 6S1P-5000mAh (2x series for 12S voltage)
Flybarless: VBAR, v4
Main Blades: EDGE 693mm Flybarless
Tail Blades: EDGE 105mm
Cyclic Servos: Align 610 (8.4V)
Tail Servo: Outrage BL 9088 (8.4V)
Main Gear: KDE Direct Main Drive Gear, 115T, MOD1.0
Pinion: RevCo 13T, MOD1.0, 6mm Bore
Headspeed: 2175 rpm governed
Pitch Range: +/- 14
Surprisingly, the LiPos were not even close to being hot after the flight (~120F) and the flight only pulled 3.9Ah for 4:30 of flying, which was great considering the abuse it was placed under!
有跳墙出去的兄弟麻烦给我们转载下这个视频  想看看到底有多厉害
http://www.youtube.com/watch?v=K4u-4_77Ylo
[ 本帖最后由 garfieldhummer 于 2010-5-24 00:52 编辑 ]
 楼主| 发表于 2010-4-28 00:11 | 只看该作者
A great website to determine motor performance (brushless motor calculator) can be found here: http://www.s4a.ch/eflight/helicalc_e.htm
It will give you a rough estimate of the performance of the motor based on the variables discussed above. Overall, you can see the performance of the KDE Direct motor in comparison:
KDE Direct 1917H/1Y-N42: Efficiency = 92.7% at 183A, 6561W output (under 12 degree pitch load, hard 3D)
Kontronik Pyro700-52L: Efficiency = 88.0% at 175A, 6003W output (under 12 degree pitch load, hard 3D)
 楼主| 发表于 2010-4-28 00:23 | 只看该作者
能不能飙到9000W不知道
但是应该就目前的电池来说
5000mah 40C的 TP LP等, 理论最大功率是4.0V*12*5*40A=9600W
5000mah35C的电池           理论最大功率是4.0V*12*5*35A=8400W
这个电流估计只有  凤凰的160A才搞得定了
希望有了解的朋友介绍更多信息:em00:
kV520 rpm/V
Maximum Power5,000+ W
Maximum Efficiency93 %
(@10V)2.2 A
Rm (Winding Resistance)0.013 Ω
Maximum Speed35,000 rpm
Rotor Poles8 (24 Pole Stator)
Shaft Diameter6 mm
Shaft Length41 mm
Motor Diameter56 mm
Motor Length83 mm
Motor Weight530 g
Cooling SystemHigh-Volume Fan and Fins
SC PWM Rate11-16 k
289美刀
[ 本帖最后由 garfieldhummer 于 2010-4-28 10:21 编辑 ]
发表于 2010-4-28 01:05 | 只看该作者
风景不是一般的好啊
发表于 2010-4-28 02:08 | 只看该作者
翻墙、下 载、上传……相当辛苦啊
:em15:
参与人数 1威望 +2 收起 理由
garfieldhummer + 2 非常感谢 翻墙很辛苦 分享很光荣
发表于 2010-4-28 09:43 | 只看该作者
这马达不就是德国Neu马达嘛,性能和质量当然不是天蝎之类香港牌子能比的了的。
发表于 2010-4-28 09:51 | 只看该作者
原帖由 失速飞行 于 2010-4-28 02:08 发表
<A href="http://player.youku.com/player.php/sid/XMTY4NTk0NjAw/v.swf:em15:" target="_blank">http://player.youku.com/player.php/sid/XMTY4NTk0NjAw/v.swf:em15:
谢谢分享,好人那,哈哈:em26:
 楼主| 发表于 2010-4-28 10:14 | 只看该作者
原帖由 xuesing 于 2010-4-28 09:43 发表
那要是和Pyro比呢?
发表于 2010-4-28 11:08 | 只看该作者
原帖由 garfieldhummer 于 2010-4-28 10:14 发表
那要是和Pyro比呢?
Pyro是Kontronik的马达,咱们只谈质量的话,K牌和Neu都是顶级的质量,只不过K牌价格高昂而Neu价格平易。 KDE的这款马达是和Neu合作的,Neu应KDE的要求做了一些改进。
我上面有提到天X马达,因为我自己用下来天X马达的质量和做工说实话我看不上,但是性能在马达还是新的时候还是不错的。香港和大陆很多自主品牌的问题在于刚买的时候还好用,但是不持久不耐用,而且产品质量不十分稳定。
发表于 2010-4-28 11:34 | 只看该作者
极品马达:em26: 还有个牌子ORBIT也应该算极品了,德国佬的东西就是好:em07:
 楼主| 发表于 2010-4-28 11:45 | 只看该作者
原帖由 xuesing 于 2010-4-28 11:08 发表
我上面有提到天X马达,因为我自己用下来天 ...
那个毒虫马达自己都说了是高性价比   哈哈
如果按照你所说  那么看来蝎子的耐用性的却离顶级产品有一定的差距
那老牌的Hacker的马达呢? 怎么现在很少有动静了?
发表于 2010-4-28 17:54 | 只看该作者
又见怪兽:em17:
发表于 2010-4-28 21:09 | 只看该作者
太危险
发表于 2010-4-28 22:37 | 只看该作者
:em07: :em07: :em26:
发表于 2010-4-29 08:13 | 只看该作者
:em26:
发表于 2010-5-1 10:49 | 只看该作者
比机还贵的电机:em15:
发表于 2010-5-25 09:37 | 只看该作者
越看就越觉得油的......................
油的始终只能是那样...
发表于 2010-5-25 14:09 | 只看该作者
这个电机差不多2000块
 楼主| 发表于 2010-5-25 23:15 | 只看该作者
原帖由 abc127 于 2010-5-25 14:09 发表
这个电机差不多2000块
200-230美金吧
发表于 2010-5-27 20:31 | 只看该作者
用怪兽来形容一点不过。。
