查看: 4187|回复: 9
号外!Mini Vbar只要2***RMB
发表于 2010-6-25 00:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
不好意思  炸鸡之王  看到发的帖子特意去看了看  还真的是惊喜,不过也有些地方搞不懂,所以单开贴请高手进来看看
              Mini VBar
The Mini VBar is the world’s smallest and lightest 3-axis virtual flybar system. It is designed to fit most electric helicopters. Despite its small size, the Mini VBar is equipped with top-quality sensors and will thus satisfy the highest performance expectations. Programming is done via a control panel, or via USB using the PC software. A special feature of the Mini VBar is the option to use it in conjunction with one or two 2.4 GHz satellite receivers (you may choose from various brands). This feature renders it unnecessary to use a primary receiver. It is also possible to connect the Mini VBar to a receiver in the conventional way.
    MiniVBar operates with the following satellite receivers: Spektrum, Fasst, Jeti Duplex.
The all new Mini V-Bar can now be used in all electric model helicopters with only a few limitations: Do not use the Mini V-Bar in the following types of helicopters:
- Scale helicopters
- Helicopters with multi-bladed rotorheads (3+ blades)
- Helicopters with push-pull linkages
- Custom built/self-made helicopters.
    3-Axis Gyro System
    Dimensions: 28 x 37 x 13 mm
    Weight: 11 g
          Content of MinVBar set: Mini VBar with 5.0 Express-Firmware and PC-Software Version 5.0, USB cable
(satellite receivers and control panel are not included)
[ 本帖最后由 garfieldhummer 于 2010-6-25 00:18 编辑 ]
 楼主| 发表于 2010-6-25 00:15 | 只看该作者
我的第一反应是,查汇率,算下来是将近2336RMB
第二反应,肯定阉割了,往下看,果然阉割了
不过当接收机的功能还在 , 阉割了哪些呢?
如下直升机不能使用:
比例像真机(传感器不够强大?)
桨大于3叶的直升机(这个不理解,算法不支持?)
有推拉设计的?( push-pull linkages)难道是舵机推拉系统
自制和定制的直升机(难道还有个List推荐的飞机?)
欢迎大家继续讨论
如果性能又棒,这个价格还真的让人心动哦,3G 的竞争就激烈咯
发表于 2010-6-25 00:25 | 只看该作者
支持!
发表于 2010-6-25 09:28 | 只看该作者
强烈关注。。。。。。:em04: :em04:
发表于 2010-6-25 09:50 | 只看该作者
这价格,这性能,无敌了
发表于 2010-6-29 22:21 | 只看该作者
对那些限制条件非常不解。。。都可以升级5.0完全版软件,算法应该不会与其他V8有区别啊
至于传感器换成低成本的,据说是为了提高V8的市场竞争力,还据说此传感器仍然具有顶尖性能。不解啊:em04:
发表于 2010-6-30 23:52 | 只看该作者
为什么不考虑SK720?
很强的功能~
发表于 2010-7-3 01:21 | 只看该作者
SK720自动平衡
发表于 2010-7-3 23:22 | 只看该作者
期待测试结果:em15:
发表于 2010-12-4 22:26 | 只看该作者
:em03:
