在本论坛内看了很多多旋翼超长留空时间的帖子 也问过很多人 什么配置怎么搞 可是不是不回复就是回一些没有营养的话!
我觉得模友就应该有互帮互助 分享成果和经验 这样所有的模友才能有共同进步!别那么看重利益
好了少说话 多分享 我在国外论坛上看到的 多旋翼超长留空的配置一一分享给我们国内的模友参考参考
您的一个回复 也许少让一个模友走弯路! 谢谢
1.----------65分钟29秒
电机: Hobbyking NX-4006-530KV
电调: Hobbywing 18A Flyfun
螺旋桨: Graupner 14x8 E-prop
电池:品牌maxamps 2x4S11000
飞控: KK-board SW 4.7
起飞重量: 2400克
2-------------------3轴飞行器28分钟的
电机: HK NX-4008 620kv motors
电调: 18A Plush ESC HK
电池: 2个4s 3300毫安
2个电池重量: 750g
3轴重量: 750g
AUW: 1.5KG
Total thrust: 3.2kg
3--------------------这是飞60分钟的配置
Frame
机臂: 3/4" x 3/4" fir stick (approx 5 ft)
中心板: 1/4'' or 5mm Plywood (approx 6"x18”)
Machine screws & bolts, and washers
landing gear: 4 wiffle balls
zip ties
battery mount: 3/8" x 3/8" stick (approx 1 ft)
Bamboo Skewers
Piece of soft foam about 1/2'' thick, slightly bigger than your flight control board
velcro, double-sided(approx 8'')
velcro, single-sided, sticky, soft side (approx 6'')
Power System
battery: LiPo 3S 3000-4000mAh (we like this one: 3S 3000 mAh 25-50C)
4 x 40A Turnigy Plush ESC (motor controller)
4 x NTM 35 1100 KV motors
2 10"x3.8" APC SF Props
2 10"x3.8" APC SFP (counter clockwise) props (buy some extras of each prop for when you crash)
power distribution board, presoldered or homemade power distributor
Radio System (remote controller)
This is what we use regularly:
HobbyKing 9xr
FrSky module and receiver
Here's a cheaper entry-level system.
Flight Control Board
There are quite a few options available. Here are two options that I've used and can vouch for:
3D Robotics Ardupilot Mega ($234). full featured autopilot, full autonomous operation, ground control capabilities.
HobbyKing KK2 ($30). basic quadcopter flight, acrobatic and stabilized modes.
搞笑配置 留空时间 2小时以上
氦气球版多旋翼
起飞重量2.5KG
