查看: 18674|回复: 106
Turnigy 9XR 已经在 Hobbyking 铺货了
发表于 2012-12-25 06:30 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
基本就是一个富斯9加上重新设计外观并集成了USB通讯功能,且将原来的干电池换成了3S锂电池。自带ER9x的固件并可通过USB升级。支持可换模块,据说是可以兼容原有的9x接收机并通过换模块兼容JR/Spektrum接收机。
此外该控还同时提供JR和Futaba的模拟接口,感觉是对原有的富斯9的一个升级版。
目前9XR的上市价格为$49.99元,DSMX/DSM2的RF模块报价$29.95。
 楼主| 发表于 2012-12-25 06:36 | 只看该作者
 楼主| 发表于 2012-12-25 06:37 | 只看该作者
HobbyKing 上的英文产品描述:
The greatly anticipated Turnigy 9XR has arrived!
The software for the 9XR first began development 6 years ago. Since then it has been tweaked, tuned, changed, updated and revamped by members of the R/C community into a powerful - yet easy to use interface. Our engineers designed the physical product around the R/C communities software changes and input. The culmination of all these is the Turnigy 9XR!
For many users this will be the perfect 9 channel radio straight out of the box, but there are many tinkerers out there who love modifying and pushing the boundaries of what is possible from their radio. We have factory fitted the 9XR with an AVR ISP header to simplify the development of custom software, we have launched turnigy9xr.com as the epicentre for software developers and additional community support for all 9XR users......With the 9XR we encourage it!
The 9XR is supplied preloaded with top quality software which is full of features and yet remains easy to use. Our aim was to develop a radio for you, the hobbyist, with an extensive list of standard features usually expected from a radio system 3 times the price. Our Turnigy 9XR is everything you imagined and more!
9XR Standard Features: 9XR基本功能:
• 8 Channel PPM/9 Channel PCM 8通道PPM/9通道PCM
• Full Ball Bearing gimbals 全轴承摇杆
• Adjustable Stick Length 可调摇杆长度
• Digital Trims on all Primary Axis 数字微调
• 16 Model Memory 16组模型
• Assignable Switches 开关可自行设定功能
• Freely Assignable Channel Mixes 任意通道混控
• Graphical Dual Rate and Exponential 图形化D/R以及EXP
• Sub Trim and Travel Adjust 微调和行程调节
• Flaps and Differential 襟翼和差速
• Throttle Hold 油门锁定
• Supports Heli/ Aero/ Glider Model Types 支持直升机/飞机/滑翔机模型
• Programming Templates Based on Model Type 基于模型的编程模板
• Supports M1, M2, M3, M4 stick modes 支持4种摇杆模式Mode1-Mode4
• 128 x 64 backlit Liquid Crystal Display 128x64带背光液晶显示屏
• Built in JR & Futaba Trainer Ports 内建JR和Futaba教练接口
• PPM & PCM Output PPM和PCM输出
• JR Form Factor RF Modules (Orx Dsm2, Orx Open LRS 433Mhz etc) JR发射模块
• Programmable Timers 可编程计时器
• Low Voltage Warning and Buzzer 低电压报警
• Supports 3s Lipo (Required) 支持3S锂电池
• 9XR Firmware Pre-loaded 预装9XR固件
• AVR ISP Interface AVR ISP界面
• Internal 2.4GHz Antenna 内建2.4GHz天线
Online support and user forums available at: www.turnigy9xr.com
Spec:
Channnel: 8ch ppm/9ch pcm
Display: 128*64LCD (Backlit)
Support Type: Heli/Acro/Glid
Model Memory: 16
Stick modes: 1, 2, 3, 4
Encoder type: ppm/pcm
Module Interface: JR Compatible (See Related Items Below)
Simulator Interface: Yes (JR & Futaba)
Buzzer: Yes
Required:
Battery 3S Lipo
RF Module
Included:
Turnigy 9XR Transmitter (Mode 2 – Throttle on Left Stick)
Quick Start guide
Note: This version is supplied without an RF Module, Please order the relevent RF module from the accessories list below.
发表于 2012-12-25 07:31 | 只看该作者
看上去不错哈
发表于 2012-12-25 07:42 | 只看该作者
发表于 2012-12-25 08:35 | 只看该作者
发表于 2012-12-25 08:40 | 只看该作者
看起来不错~~
发表于 2012-12-25 08:46 | 只看该作者
发表于 2012-12-25 08:53 | 只看该作者
蓝的好低档
 楼主| 发表于 2012-12-25 09:08 | 只看该作者
ejing1998 发表于 2012-12-24 19:53
蓝的好低档
是啊,我觉得背光要能换成淡绿色会好很多。
发表于 2012-12-25 09:09 | 只看该作者
确实,这个蓝屏看起来档次一下就下来了,而且感觉还看不太清楚
发表于 2012-12-25 09:29 | 只看该作者
不到50刀,这么便宜啊
看上去不错啊
发表于 2012-12-25 09:35 | 只看该作者
这个提手看上去真的好性感啊
发表于 2012-12-25 09:38 | 只看该作者
想知道国内售价
发表于 2012-12-25 09:58 | 只看该作者
发表于 2012-12-25 10:14 | 只看该作者
价格对得住这机器。。
发表于 2012-12-25 10:16 | 只看该作者
价格对得住这机器。。
发表于 2012-12-25 10:47 | 只看该作者
谁出的?
发表于 2012-12-25 10:48 | 只看该作者
为啥一道国内价格翻一翻
