查看: 2173|回复: 4
EXCELLENT WORKMANSHIP ZERO-TECH XPLORER UAV GOPICUTE
发表于 2015-8-12 10:54 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
This timewe use excellent pictures to bring you to feel the workmanship of ZERO-TECHXPLORER. From my careful observation, the modular design of ZERO-TECH XPLORER isingenious, and the workmanship can also be said it is at the best level of domesticUAV area.
We talk about the ZERO-TECH XPLORER V, which is the version withthree axis stabilized Gimabal and 1080p Full HD camera.
The ZERO-TECH XPLORER’s originalpropeller is Non-self locking, but its motors can compatible with the selflocking propeller in the market, so I bought one set and installed before theshooting.
ZERO-TECH XPLORER’s  appearance showing a different feeling oflines, the straight lines make people feel very resolute. Some may think thatit is like a dart, whether it will not enough flow and easy to produce windresistance during the flight? In fact, these concerns are redundant, turn toanother angel, we can see that the body of ZERO-TECH XPLORER is so fuselage andthe wind resistance is not a big problem.
Under the fuselage body of ZERO-TECH XPLORER, there are twomodules, one is the three axis stabilized Gimbal and the HD camera.
With the module design of ZERO-TECH XPLORER , we can rapidlychange the broken parts, and also can rapidly disassembleand assemble when you carry it around.
Summary:
The ZERO-TECH XPLORER’s workmanship canmake people satisfied, the body is fully expressed in the design of humannature, and the price of ZERO-TECH XPLORER is just 3999rmb, which I think isquite worth.
发表于 2015-8-12 13:03 | 只看该作者
高度  别多了 如果能提升到200米,图传再好点,就这外形,谁还买大疆啊
发表于 2015-8-12 12:28 | 只看该作者
发表于 2015-8-12 11:32 | 只看该作者
[tr]电梯直达
[tr]楼主
[tr]发表于2015-8-12 10:54 [tr]| [tr]只看该作者 [tr]|[tr]只看大图 [tr]|[tr]倒序浏览 [tr]|[tr]阅读模式
[tr=none]这个时候我们使用优秀的图片给你带来的感受zero-techxplorer做工。[tr=none]我仔细观察,zero-tech Xplorer的isingenious模块化设计,而且做工也可以说它是在domesticuav地区最好水平。
[tr]6654376_02_thumb.jpg [tr](44.56 KB,下载次数:0)
[tr]下载附件
[tr]2015-8-12上传10:44
[tr]我们谈论的zero-tech Xplorer的V,这是版本三轴稳定gimabal和1080p全高清摄像头。
[tr]6654376_03_thumb.jpg [tr](46.77 KB,下载次数:0)
[tr]下载附件
[tr]2015-8-12上传10:48
[tr=none]的zero-tech Xplorer的originalpropeller是非自锁,但其电机可以用自锁螺旋桨在市场兼容,所以我买了一套安装前拍摄。
          [tr]6654376_04_thumb.jpg [tr](40.82 KB,下载次数:0)
[tr]下载附件
[tr]zero-tech Xplorer的外观呈现出不同的感觉,直线线条,让人感觉很坚决。[tr]有些人可能认为它是像一个飞镖,是否会没有足够的流量和容易在飞行过程中产生的阻力?[tr]事实上,这些担心是多余的,把另一个天使,我们可以看到,zero-tech Xplorer的身体是如此的机身和风的阻力并不是一个大问题。
[tr]6654376_05_thumb.jpg [tr](45.06 KB,下载次数:0)
[tr]下载附件
[tr]2015-8-12上传10:51
[tr]zero-tech Xplorer的机身下,有两个模块,一个是三轴稳定框架和高清摄像头。
[tr]6654376_06_thumb.jpg [tr](38.59 KB,下载次数:0)
[tr]下载附件
[tr]上传2015-8-12 10:52
[tr=none]随着zero-tech Xplorer模块设计,我们可以rapidlychange破碎的部分,也[tr]能迅速[tr]disassembleand组装时,你可以随身携带。
[tr]6654376_07_thumb.jpg [tr](43.1 KB,下载次数:0)
[tr]下载附件
[tr]2015-8-12 10:53上传
[tr]总结:
[tr=none]的zero-tech Xplorer的做工让人满意的,身体是人性的设计充分表达,和zero-tech Xplorer的价格只是3999rmb,我认为这是值得的。
发表于 2015-8-12 11:31 | 只看该作者
