查看: 2006|回复: 1
[求助帖] pixhawk2.1 Cube 针脚定义
发表于 2017-11-2 09:51 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
点击查看详情
求pixhawk2.1 Cube 飞控各端口的的针脚定义,数传和空速的转接口线序对不上?
 楼主| 发表于 2017-11-3 20:21 | 只看该作者
已找到(见图片附件),地址:https://docs.px4.io/en/flight_controller/pixhawk-2.htmlThe datasheet from Hex manufacturing can be found here.这里
另外,这款飞控的CSN接口有问题!!!
IssuesThe UAVCAN port labelled CAN1 does not work
At time of writing (October 2017) the CAN1 and CAN2 silk screen on the Pixhawk 2.1 is flipped (CAN1 is CAN2 and vice versa). The CAN2 port (labeled as CAN1) is not functional as it requires an external transceiver. The CAN1 port (labeled as CAN2) should be used as it has the transceiver built in.
标有“CAN1”UAVCAN端口不能工作至今为止(201710),在Pixhawk2.1上的CAN1CAN2丝印被翻转了(CAN1CAN2,反之亦然). CAN2端口(标签为CAN1)不能正常工作,因为它需要一个外部的收发器. CAN1端口(标签为CAN2)应该可使用,因为它有内置的收发器.
pixhawk2.1接口针脚分配
pixhawk2.1接口针脚分配
