原帖由 老金 于 2009-2-20 22:17 发表
电池仓里有一个印有批次的小标签
受影响的批次:809E, 810E, 811E, 812E
原文不是这个意思:
Radios with a date codes of 809E, 810E, 811E, 812E should be carefully checked. If your radio does not have a date code, the test is still advisable. And please, as is common, check your controls before flight.
原文是说这几个批次的要特别注意,如果没有这个日期标,建议做一次检测。并且建议在飞行之前检测一下自己的控。 |
