查看: 3513|回复: 8
Helifreak logo600se Kit + HK5020 初期测试报告
发表于 2010-6-7 22:14 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
原帖地址
http://www.helifreak.com/showthread.php?t=212100
The "happy truck" came today, and gave me a Logo 600 SE full kit.
To speed-up the experience, I used the boom, boom supports, tail control rod and belt from the kit to "convert" one of our existing Logo 600's.  I'll build the full kit ASAP though.  No such thing as too many helis, right ?
Ready to fly with Scorpion 5020-450, Thunder Power 2X5S 5000 mah 45C battery, Jive 120, Edge 693 mains and Edge 105 tails with canopy on is 9 pounds 9 ounces (4.34 kg).  CG balance is almost perfect with the packs all the way back in the frames.
Unbelievably light for a "700" size heli.  Waiting for Kyle to get home from school to take it out for a test drive .
(-:  Dave
大致信息:
logo600se Kit
蝎子5020-KV450, TunderPower 5000mah 45C
Jive 120A
EDGE693大桨,EDGE105尾桨
全重含电池4.34kg
重心几乎完美
[ 本帖最后由 garfieldhummer 于 2010-6-7 22:53 编辑 ]
发表于 2010-7-27 18:21 | 只看该作者
KONTRONIK的  JIVE120啊,还真是。。。啥时候才能也有一套那:em07:
发表于 2010-6-10 09:52 | 只看该作者
蝎子5020更实用是700机
:em24:
 楼主| 发表于 2010-6-8 22:48 | 只看该作者
回复 6楼 真有意思 的帖子
600se kit 原厂106T
发表于 2010-6-8 15:02 | 只看该作者
主齿(大齿)是多少T,麻烦告知一下,上文没有,谢!
发表于 2010-6-8 14:27 | 只看该作者
小心散了架:em19:
发表于 2010-6-7 23:24 | 只看该作者
好JJ呀!:em07: :em07:
 楼主| 发表于 2010-6-7 22:57 | 只看该作者
文字太多了  只是摘了最有用的信息,也就那个最佳搭配
14T  1900rpm  11.5°螺距
对测试报告有一点点失望,可能是暴力配置看多了吧。这一次塑料机的强度有些被限制住了,:em10: ,如果要2000rpm 14°螺距以上爆操,估计得等logo700这只神兽的出现了。不能等的就上Aurora90E,Align700e了,2200rpm,随便操:em15:
希望对上600se的朋友有所帮助:em00:
 楼主| 发表于 2010-6-7 22:15 | 只看该作者
For those interested, we’ve managed to get some flying done with our new Logo 600 SE over the past two days.  See the set-up posted earlier in this thread.
  Since the “Logo 600 stretch” is not a new idea, most of what I’ll say probably has been covered by those already flying them.  But this is the first time Kyle has never had one in his hands.
  When comparing the standard Logo 600 and the SE, other than the words “Logo 600” in their names, the similarities stop there.  They are two different helis in flight characteristics, each having their own unique qualities.
  Some stats: Air temp. was 80 degrees F (27 degrees C) on both days, wind was 10-15 mph (16-25 kph) (which was good as we were able to assess the model in a little wind).  Motor temp. averaged (with Kyle doing 3D work) 138 degrees F (59C), and ESC 100 degrees F (38C).
  Over a two day period we tried 13, 14 and 15 tooth pinions, collective pitch ranges between +/- 10 to 14 degrees, and head speeds 1800, 1900 and 2000.
  We never flew longer than 6.5 minutes, but never shorter than 5 minutes.  I can’t say specifically how much time you could get for any particular flying style / head speed combination, as Kyle would mix styles during all the flights, and we adjusted the flight time “on the fly” based on what he was doing with the heli during each flight.  However, we never used more than 75% of a 5000 mah pack’s capacity on any flight.  I’ll conclude that if you ran 1800 head speed and cruised around doing forward flight aerobatics and light 3D, you could get longer then 6.5 minute flights for sure.
  Rather than a flight-by-flight report (take forever…this is long enough already), here’s the deal: the “sweet spot” for Kyle with the set-up was on a 14 tooth pinion, 11.5 degrees collective pitch @ 1900 head speed.  14 degrees of collective pitch is too much for the power system to reasonably maintain its head speed.  Using a head tack and observing the heli during 3D maneuvers, we lowered the pitch to 12 degrees, then 11 degrees, and then settled on 11.5 degrees as the threshold between the most pitch you can use and still have the head speed stay reasonable constant through tough 3D maneuvers.  The heli is very capable for sure with these numbers.
  It’s all about what feels right for each pilot however.  Kyle felt 1800 on a 13 tooth was too timid for him, but the heli was still fully 3D capable, yet had a more mild feeling to it…and would of course produce longer flights.
  2000 head speed on a 15 tooth was over the limit for our machine.  We established the “over the limit” threshold by putting in a flight with 14 degrees of collective pitch at 2000 head speed, and Kyle hammered the heli hard for the whole flight.  Our set-up includes the 5020 motor (which is no lightweight), and 5000 mah packs, so it’s on the “heavy” side as this model goes I’m told (if you want to call a 9 ½ pound 700 class heli “heavy”).    After the flight a close inspection of the head dampners (we were warned about this so knew where to look), showed signs of the small black washer between the o-rings and inside blade grip radial bearing, starting to cut into the o-ring.  There was a small sliver of rubber in one of the gaps between the head and the grip.  That was the last flight of the day.  On disassembly later that night, the dampners showed signs they didn’t much like that kind of abuse.  However, the dampners already had over 50 flights of hard 3D flying on them prior to the test.  But still, we find no reason to go into that flight regime, as the heli flies great and is very capable using more conservative numbers.
  In summary:
  The thing Kyle disliked most about the SE, was due to the large disc size and the relative lightness of the machine, in maneuvers where the disc was vertical and with the wind blowing, the disc was kind of like a sail being blown in the wind.  You have to correct more to maintain your position relative to a fixed point on the ground as compared to a standard Logo 600.  Other than that, no bad tendencies at all.  Flies like a dream.
  The thing Kyle liked best was a result as well of the larger disc and light weight.  The heli will stop on a dime.  As an example: while performing a forward flip to a stop and reverse from high speed forward flight, the momentum of the standard Logo 600 requires a certain amount of patience for the heli to slow down during the flip, and using negative collective, get it going in the opposite direction.  The SE on the other hand, once you flip it forward and present that large disc to the on-coming airflow, it stops “right now”.
  Also, it will hang in an auto forever, and ever, and ever…(-:
  One last note: Although we will “fine tune” the V-Bar settings for the SE as we go, looking for subtle improvements where possible, other than the changes to the collective range and lowering “pitch pump” down from 25 to 10, the SE was flown with the exact same V-Bar settings as Kyle uses with his standard 600’s.  There was no “pressing need” to change anything for it to fly really well.
  (-:  Dave
测试范围:
13-15T
1800rpm-2000rpm
10-14°螺距
飞行时间:最长不超过6分30秒,最少不小于5分钟。电池放电量均少于75%
          如果用1800rpm的定速,应该可以更长。
最佳搭配:
14T,11.5°螺距,1900rpm转速
其他搭配:
14T,1900rpm,14°,马达很难维持转速,不推荐
15T,2000rpm,15°,完全超越机体极限,结果是,横轴垫圈割入了O圈,还有些其他的损伤
(After the flight a close inspection of the head dampners (we were warned about this so knew where to look), showed signs of the small black washer between the o-rings and inside blade grip radial bearing, starting to cut into the o-ring.  There was a small sliver of rubber in one of the gaps between the head and the grip.  That was the last flight of the day.  On disassembly later that night, the dampners showed signs they didn’t much like that kind of abuse.  However, the dampners already had over 50 flights of hard 3D flying on them prior to the test.  But still, we find no reason to go into that flight regime, as the heli flies great and is very capable using more conservative numbers.)
