查看: 1289|回复: 1
大vbar 5的尺寸和重量是多少?
发表于 2010-12-20 13:28 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
各处都只有mini vbar5的尺寸和重量,有谁知道大vbar 5的尺寸和重量吗?
发表于 2010-12-20 14:09 | 只看该作者
VBar "Blueline" 5.0 Express
Get rid of the flybar and go to an entire new dimension of flying! The VBar system is an electronic gyro system for three axes, including a tail rotor gyro.
new 5.0 Software for outstanding flight performance
easy start with programming assistent
VBar can be used in conjuction with one or two satellite receivers
Programming via PC/Control Panel
Specifications
Dimensions  Main unit 45,5 x 33,8 x 16 mm Gyrosensor 28,5 x 28,5 x 10 mm
Weight  Main unit 15,9 g Gyrosensor 10,5 g
Content
USB cable  1,8 m
Patch cable  Patch cable for Standard Receiver
mounting pad  yes
main unit  yes
Gyrosensor  yes
Manual  printed manual
Software  CD with drivers and PC-Software
:em00:
