2148 - PRO-8 Charger Balancer
Microprocessor controlled high-performance digital rapid charger/discharger for
NiCd, NiMH, Li-poly and Pb batteries. Designed to maintain your battery at its best condition
DC entry.
Charge/discharge current up to 7A.
10 data memory.
1~8 series Li-ion/poly.
1~27 cells NiCd/NiMH with adjustable Delta-peak sensitivity (mV).
6,12 and 24V lead acid (Pd) batteries.
3-8 cell balance mode.
1-5 charge/discharge cycles.
Microprocessor controlled.
Efficient cooling system with automatic cooling fan.
Temperature cut-off.
"Auto" function; every program is controlled in order to prevent every possible error so it guarantees a maximum safety.
Operating program upgrade; the operating program can easily be upgraded through the external port
Upload of data is possible via the integrated USB port. An USB cable and software are included. You can monitor all the important parameters (Volt, Amperage, cell per cell status of LiPo batteries, ...) on your pc.
Input power monitor: the input voltage is always monitored. If it drops below the lower limit the process will be ended automatically.
Capacity limit: if preset, the process will be terminated automatically.
Various cables are included in the packaging.
Technical specifications
Charge 0,1~7 A
Charge & Discharge 1~5 cycles
Cooling Yes
Discharge 0,1~5 A
Input Power 11~18 V
LiPo cell(s) 1~8
Memory 10
Model PRO-8
Multi Conn. Included
NiMH & NC cells 1~27
Output Power 0,1~7 A
Pb Battery 6V-12V-24V
Temp. sensor Yes
USB Yes |
