查看: 2215|回复: 16
9257杀手来咯!!
发表于 2007-12-3 09:05 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Hitec is proud to announce the HG-5000 micro heading lock gyro with the “extreme speed” HSG-5083MG Digital Micro Tail Rotor servo.
The HSG-5083 was built specifically for the HG-5000 to obtain optimum performance in the T-Rex 400-450, Helimax 400-450 or similar class of electric helis.
At 0.35 oz the HG-5000 is very light and small, yet yields performance equal or better than any other Gyro available.  Stock #44192 (Gyro & servo) | MAP $199.99
 楼主| 发表于 2007-12-3 09:08 | 只看该作者
Micro Digital Servo for HG-5000 use only·
Optimized for 400-450 class EP Helicopters
All Metal Gear (1st MP Gear)
Size: 1.14” x 0.51” x 1.18”
Weight: 0.74 oz
Torque at 4.8V: 20.85 oz.in
Speed at 4.8V: 0.07 sec/60 deg
Fastest Servo Hitec has ever made!
全金属齿,一颗轴承,20克,1.7KG扭矩,0.07sec/60 deg:em15: :em26:
 楼主| 发表于 2007-12-3 09:09 | 只看该作者
·    Optimized High Response Narrow Band Hitec Signal
·      Best with Hitec HS-5083MG
·      Universal Signal Selectable (both Digital & Analog)
·      Precision Control Technology for Heading Lock
·      Auto Detection for any Transmitter & Receiver
·      No initializing Time - Powering up in Head Lock Mode
·      Extreme Tolerance against Disturbance and Vibration
·      Advanced Real Time Sensor for Drift Removal
·      Remote Gain Adjustment
·      Light Weight & Compact Size
·      Self Diagnosis Function
·      Simple and Vivid LED Display
·      Easy Data Setting
·      Low Power Consumption (20mA)
·      Size: 0.86” x 0.86” x 0.43” | Weight 0.35 oz
:em24:
发表于 2007-12-3 09:29 | 只看该作者
哇,不知道在大陆有木有市场。
发表于 2007-12-3 09:49 | 只看该作者
这个陀螺的版本可真是多!现在OEM太严重了!
发表于 2007-12-3 10:19 | 只看该作者
5083MG,不知道有多大的力!
发表于 2007-12-3 10:43 | 只看该作者
不知道有谁用过!!
发表于 2007-12-3 10:50 | 只看该作者
没价格优势别想取代9257,价格不知道会是多少
发表于 2007-12-3 10:55 | 只看该作者
看不懂英文
发表于 2007-12-3 11:10 | 只看该作者
原帖由 sagittarius 于 2007-12-3 09:05 发表
The HSG-5083 was built specifically for the HG-5000 to obtain ......
200美元的价格是没有任何竞争力的:em15:
发表于 2007-12-3 12:19 | 只看该作者
原帖由 浪人老枪 于 2007-12-3 11:10 发表
这个是在打劫啊:em08:
发表于 2007-12-3 13:36 | 只看该作者
力矩不大,只有1.5KG左右,比9257小了25%。。。
发表于 2007-12-3 14:32 | 只看该作者
有什么优势
发表于 2007-12-3 16:13 | 只看该作者
200dollar,韩国人疯了
:em17:
发表于 2007-12-4 20:12 | 只看该作者
准确的说,去买的人疯了 :em15:
发表于 2007-12-4 20:28 | 只看该作者
速度挺快的。
发表于 2007-12-4 20:59 | 只看该作者
杀手?我怀疑是自杀而已:em15:
