查看: 16705|回复: 71
黑羊TBS Crossfire Micro TX v2.40 新版固件发布,发射功率提升到250mW
发表于 2018-8-22 11:10 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
之前Crossfire Micro TX最大发射功率是100mW,新发布的FW 2.40将最大发射功率提升到250mW。
可以通过LUA菜单中选择(25mW、100mW和250mW)。
控制距离提高有30%以上。
 楼主| 发表于 2018-8-22 11:11 | 只看该作者
         2018-08-20 ( including versions from V2.25 to V2.40 )
Most important changes:
        - added: 250mW RF power option for micro TX
        - added: DSMX support for diversity (Output 8), micro and nano (Output 1) receivers
        - added: GPS speed and heading added to OpenTX telemetry stream
        - added: Ability to unlock up to 2W RF power if CROSSFIRE is powered from RC or HT port.
        V2.40         2018-08-20
                - fixed: Hide FLARM settings for micro and nano receiver
                - fixed: Show RC over MAVLink option for nano receiver
        V2.33        2018-06-08
                - fixed: exception caused by certain MAVlink frames
        V2.32        2018-05-18
                - fixed: TX stuck on 10mW after OTA firmware update until the next power cycle
                - fixed: Minor bug fixes and improvements
        V2.31        2018-04-18
                - added: LQ is shared in new format for OpenTX telemetry and receiver output. Recommended
                          warning level is around 70%. RFMD can be excluded for OpenTX remotes warnings
                          ( Important!: Unlock on the users own risk. Remote needs to be capable of supplying  up to 3.5W )
                - added: CRSF parameter about screen added for receivers
                - fixed: ET Vector "Sensor error" warning fixed when CROSSFIRE is connected to Vector by BST
                - fixed: Fixed SBUS to work with DJI A3 flight controller
                - added: FLARM no track flag selection added (tracking is enabled by default)
                - updated: FLARM license updated
        V2.25        2018-02-18
                - fixed: Bind across different region settings
                - improved: Telemetry lost timeout increased
                - improved: Unlock for Micro TX also possible if no receiver is bound
发表于 2018-8-22 11:59 | 只看该作者
        - a ...
出于习惯,升到最新。 不过还真用不到。 100mw足够用了, 图传限制了距离。
 楼主| 发表于 2018-8-22 12:16 | 只看该作者
最大设置250mW,再开启dyn Power,根据信号自动调节输出功率。
 楼主| 发表于 2018-8-22 12:18 | 只看该作者
以前有人可以硬改Micro TX,直接输出250mW。
https://www.youtube.com/watch?v=6WSkQePf-EI
发表于 2018-8-22 13:45 | 只看该作者
看多了怎么觉得黑羊也是国内某企业代工的
发表于 2018-8-22 18:04 | 只看该作者
不用改硬件,一讚
 楼主| 发表于 2018-8-22 18:32 | 只看该作者
如果CROSSFIRE由RC或HT端口供电,则能够释放高达2W的RF功率。
TBS Crossfire 标准版也有提升,外置供电最大输出功率可以达到2W(2000mW)。
 楼主| 发表于 2018-8-22 20:47 | 只看该作者
jianghui_1990 发表于 2018-8-22 13:45
看多了怎么觉得黑羊也是国内某企业代工的
TBS 黑羊公司就在HK,牛头角 励业街同利工业大厦,原来老启德机场旁边,周围一堆工业大厦。
发表于 2018-8-22 21:40 | 只看该作者
刷了TX,还要刷RX,为了刷RX还要拆机按按钮。终于折腾完了。我设了250mw报警,TX如果切到250mw,我就返航,万无一失了吧。
 楼主| 发表于 2018-8-23 10:01 | 只看该作者
reach3 发表于 2018-8-22 21:40
刷了TX,还要刷RX,为了刷RX还要拆机按按钮。终于折腾完了。我设了250mw报警,TX如果切到250mw,我就返航,万 ...
升级AKK 1200mW图传,还可以再远飞。
发表于 2018-8-23 11:00 | 只看该作者
AKK 是什么图传?
发表于 2018-8-23 12:11 | 只看该作者
就提高50%的功率, 没什么明显区别吧。
发表于 2018-8-23 22:02 | 只看该作者
這個圖傳飛32km. 還沒極限,手上全都中小型機,沒大型機再試更遠。暫時這支akk 應該是最强5.8g 啊
发表于 2018-8-24 08:51 | 只看该作者
32km?需要天线追踪装置吗?我飞得低,一般不超过两树高,800mw也过不了1km。
发表于 2018-8-24 09:00 | 只看该作者
不用,人肉aat 已經可以了
发表于 2018-8-24 09:18 | 只看该作者
lun606 发表于 2018-8-24 09:00
不用,人肉aat 已經可以了
1200mw图传,人肉aat, 32KM? 你说的我不信。 除非眼见为实。
发表于 2018-8-24 09:22 | 只看该作者
竟然淘宝查不到?
发表于 2018-8-24 09:25 | 只看该作者
有圖有影片,不信沒所謂啊,這個我朋友的機,硬件跟我完全一樣。
发表于 2018-8-24 09:29 | 只看该作者
reach3 发表于 2018-8-24 09:22
竟然淘宝查不到?
國內沒賣吧
