机身套件+F3飞控+分电板
售价 $ 112.00
https://rcexplorer.se/product/bi ... 3fc-racing-and-pdb/
全部散件:
驱动部分零件:
油管装机调试教程
https://www.youtube.com/watch?v=Ot3Em2lI9y8
PID设置参数:
- Starting PIDs
- These PID’s and settings are made for the F3FC flight controller and Bicopter electronics kit.
- Please not that they are made to be a good starting point. Furter tuning might be required depending on your setup.
- resource MOTOR 1 B00
- resource MOTOR 2 A04
- resource MOTOR 3 NONE
- resource MOTOR 4 NONE
- resource SERVO 1 A07
- resource SERVO 2 A08
- mixer CUSTOMAIRPLANE
- mmix 0 1.000 1.000 0.000 0.000
- mmix 1 1.000 -1.000 0.000 0.000
- smix 0 2 2 100 0 0 100 0
- smix 1 2 1 -100 0 0 100 0
- smix 2 3 2 100 0 0 100 0
- smix 3 3 1 100 0 0 100 0
- feature -ANTI_GRAVITY
- feature TELEMETRY
- serial 1 32 115200 57600 0 115200
- aux 0 0 0 1300 1700 0
- aux 1 1 1 900 1300 0
- aux 2 2 1 1300 1700 0
- aux 3 28 0 1725 2100 0
- set gyro_lowpass_hz = 90
- set acc_calibration = -12,17,47
- set mag_hardware = NONE
- set baro_hardware = NONE
- set rssi_scale = 41
- set rc_interp_ch = RP
- set min_throttle = 1020
- set use_unsynced_pwm = OFF
- set motor_pwm_protocol = ONESHOT125
- set motor_pwm_rate = 2000
- set align_board_yaw = 270
- set current_meter = ADC
- set ibata_scale = 336
- set ibatv_scale = 336
- set servo_pwm_rate = 250
- set deadband = 5
- set yaw_deadband = 6
- profile 0
- set dterm_lowpass_type = BIQUAD
- set dterm_notch_hz = 260
- set anti_gravity_gain = 1000
- set setpoint_relax_ratio = 100
- set dterm_setpoint_weight = 0
- set iterm_windup = 50
- set yaw_lowpass_hz = 50
- set throttle_boost = 0
- set p_pitch = 60
- set i_pitch = 45
- set d_pitch = 60
- set p_roll = 45
- set i_roll = 20
- set d_roll = 15
- set p_yaw = 40
- set i_yaw = 20
- set d_yaw = 60
- rateprofile 0
- save
复制代码
