查看: 4618|回复: 47
【请广大模友注意】 太阳耀斑再现X级大爆发 地球GPS通讯或受影响
发表于 2013-5-22 14:33 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
近日NASA再次发布,5月13日太阳耀斑再次爆发,而本次能量为2013年最强值
根据NASA报道,太阳在上周末开始便爆发多次耀斑,而5月13日爆发为全年最大,也被列为最强烈耀斑,并被列入X级。这也是今年第16次X级爆发。NASA专家也提示,未来地球GPS等通讯设施可能会受影响。
预计在2013年底左右,太阳处于11年的活跃周期段,爆发事件的数量将出现上升。今年4月11日,太阳表面出现了一次规模为M6.5级的太阳风暴事件,伴随着最强太阳耀斑的形成,但是其依然属于中等规模的太阳耀斑事件。
科学家将太阳耀斑等级进行了划分,M级表示的太阳耀斑并不是非常强烈,但其可以影响到地球上的通信,直接瞄准地球释放的话,可以在极区看到强烈的极光现象。最强的太阳耀斑是X级太阳风暴,当此类耀斑直接朝向地球释放能量时,可以对宇宙飞船和空间站上的宇航员构成威胁,还可以干扰GPS信号和通讯,造成无线电中断。NASA科学家认为周五的太阳耀斑可造成短时间的无线电波通讯中断,目前太阳处于第24太阳周期,包括SDO在内的数艘NASA飞船正在不断对太阳进行监视监测,跟踪太阳活动和预报空间天气。
NASA 原文章节摘录如下:
Three X-class Flares in 24 Hours
05.14.13
Third Update: May 14, 9 a.m. EDT
The sun emitted a third significant solar flare in under 24 hours, peaking at 9:11 p.m. EDT on May 13, 2013. This flare is classified as an X3.2 flare. This is the strongest X-class flare of 2013 so far, surpassing in strength the two X-class flares that occurred earlier in the 24-hour period.
The flare was also associated with a coronal mass ejection, or CME. The CME began at 9:30 p.m. EDT and was not Earth-directed. Experimental NASA research models show that the CME left the sun at approximately 1,400 miles per second, which is particularly fast for a CME. The models suggest that it will catch up to the two CMEs associated with the earlier flares. The merged cloud of solar material will pass by the Spitzer spacecraft and may give a glancing blow to the STEREO-B and Epoxi spacecraft. Their mission operators have been notified. If warranted, operators can put spacecraft into safe mode to protect the instruments from solar material.
These pictures from NASA's Solar Dynamics Observatory show the three X-class flares that the sun emitted in under 24 hours on May 12-13, 2013. The images show light with a wavelength of 131 angstroms, which is particularly good for showing solar flares and is typically colorized in teal.
Credit: NASA/SDO
Four images from NASA's Solar Dynamics Observatory of an X3.2-class flare from late at night on May 13, 2013. Starting in the upper left and going clockwise, the images show light in the 304-, 335-, 193- and 131-angstrom wavelengths. By looking at the sun in different wavelengths, scientists can view solar material at different temperatures, and thus learn more about what causes flares.
Credit: NASA/SDO
On May 13, 2013, the sun emitted an X2.8-class flare, peaking at 12:05 p.m. EDT. This is the the strongest X-class flare of 2013 so far, surpassing in strength the X1.7-class flare that occurred 14 hours earlier. It is the 16th X-class flare of the current solar cycle and the third-largest flare of that cycle. The second-strongest was an X5.4 event on March 7, 2012. The strongest was an X6.9 on Aug. 9, 2011.
On May 13, 2013, an X2.8-class flare erupted from the sun -- the strongest flare of 2013 to date. This image of the flare, shown in the upper left corner, was captured by NASA's Solar Dynamics Observatory in light of 131 angstroms, a wavelength which is particularly good for capturing the intense heat of a solar flare and which is typically colorized in teal.
Credit: NASA/SDO
发表于 2013-5-22 14:38 | 只看该作者
这段时间无故炸机的都可以怪罪到太阳风暴上了
发表于 2013-5-22 14:52 | 只看该作者
请问DJI 会采取什么样措施呢?    全民停飞总动员?
发表于 2013-5-22 14:59 | 只看该作者
这个咋办呢???
发表于 2013-5-22 15:01 | 只看该作者
不用GPS模式是不是就行了???
发表于 2013-5-22 15:02 | 只看该作者
上次说是遥控器问题   现在又说太阳?  这不是忽悠我们用户吗?  你说太阳问题  为什么偏偏只有NAZA出问题呢?
发表于 2013-5-22 15:22 | 只看该作者
真忽悠
发表于 2013-5-22 15:28 | 只看该作者
您的理由真好
发表于 2013-5-22 15:34 | 只看该作者
赶紧直接飞到太阳上去看看什么情况。。
不错很牛~帮推
 楼主| 发表于 2013-5-22 15:53 | 只看该作者
这是温馨提示,不是什么推卸责任,我非常奇怪某些人脑子里的逻辑,以及对DJI敌对的态度。以后再有类似的情况,DJI还是会通告给广大模友注意。
发表于 2013-5-22 16:14 | 只看该作者
采取全面停飞的措施贝
发表于 2013-5-22 16:29 | 只看该作者
模友注意
发表于 2013-5-22 17:12 | 只看该作者
大約什麼時候可以正常使用GPS ??
发表于 2013-5-22 18:06 | 只看该作者
谢谢提示!
发表于 2013-5-22 20:16 | 只看该作者
下午刚刚飞了,还不错,因为是阴雨天气
发表于 2013-5-22 20:46 | 只看该作者
DJI还是很负责的,注意到了这些能提示模友,无论是什么目的但出发点是好的,不管大家说DJI的产品怎么样,但作为DJI飞控的用户,我就看不下去了,为什么你们就一直炸机呢?这是为什么呢?我玩NAZA半年多NAZA工作一直很正常,为什么我的DJI飞控就不炸呢?因为飞控问题炸机的不可能没有,各种炸鸡问题都有。所以大家不要在借题发挥转牛角尖了,解决问题才是王道,而不是各种借题发挥的声音,让DJI静心为大家解决问题,而不是一天到晚听你们各种喷。
发表于 2013-5-22 22:43 | 只看该作者
以后炸鸡就不用联系大疆了  直接找太阳吧
发表于 2013-5-22 23:20 | 只看该作者
这样的提醒很贴心,非常感谢!而且希望类似的善意提示,DJI能一直坚持下去。
一个善意的提醒,没必要非要对号入座,不管飞控再怎么可靠、再怎么完善,在任何时候都不能忘记了飞控仅仅是用于辅助飞行。
发表于 2013-5-23 05:35 | 只看该作者
提醒总比无声强
