编号 | 规格 | 单价 (500PCS) | 单价 (1000PCS以上) |
BP-S04 | Voltage of work: 4.8~6V
Current of work: <200mA
Speed: 0.10sec/60degree
Output torque: 0.5 kg.cm
Weight: 3.7g
Size: 20 x 8.3 x 17.5 mm
BP-S08 | Voltage of work: 4.8~6V
Current of work: <280mA
Speed: 0.10 sec/60 degree
Output torque: 1.4 kg.cm
Weight: 8g
Size: 22.8 x 11.8 x 20.6 mm
BP-S09 | Voltage of work: 4.8~6V
Weight: 9g
BP-S15 | Voltage of work: 4.8~6V
Speed:0.15 sec/60 degree
Output torque: 2.5 kg.cm
Weight: 15g
Size: 28.4 x 13.2 x 32 mm
BP-S35 | Voltage of work: 4.8~6V
Output torque: 3.5 kg.cm
Weight: 35g
Size: 40.8 x 20.1 x 36.5 mm
