| | | | | | Head with side-mounted jockey pulleys and optional lever-feed assembly
| | | | | | Screw-feed head with alternative drive pulley arrangement
| | | | | | The headstock is designed to be removed from the machine and used for other tasks
| | | | | | Ground and lapped spindle end
| | | | | | Demountable precision compound table with Stevens miniature precision vice
| | | | | | Table feed-screw, balanced handwheel, support tube (with ball races) and micrometer dial
