返回列表 发新帖
楼主: maojiaqiu
玩了几年了 还不知道450是什么意思?
发表于 2012-3-27 12:55 | 只看该作者
The size classes come from an old convention of naming things based on the size of the motor... not the power or anything, the actual physical size of the motor. A 400-size motor used to be a well-known thing - there is a pylon racing class called "Speed 400" which requires the use of a 400-size motor. With brushless motors now on the market though, a 400-size motor can be way more powerful than the old brushed motors, and still be technically a 400-size motor.
Now obviously, running one of those in a Speed 400 race against guys using the Cobalt 400... is gonna be a little unfair. So really, the classes don't mean a whole lot of anything anymore, but they have a historical meaning.
These days though, the size classes are still used, and while they are somewhat ambiguous, they are less useless than the class names such as "mini" and "micro"
And as has been pointed out, the best objective comparison method is to use blade size.
less than 200mm blades - 100-class - "ultra-micro" - (Blade mSR)
200mm blade - 200-class - "micro, or sub-micro, I don't know" (Trex 250, Gaui 200)
290mm blade - 300-class - "micro, I guess" (Blade CP, Honey Bee)
325mm blade - 400-class - "mini" (Trex 450, Blade 400, Mini-Titan)
425mm blade - 500-class - "helicopter sized?" (Trex 500, Protos)
600mm blade - 600-class - "large electric?" (Trex 600, Mikado Logo 10)
There are some blurry lines there...
发表于 2012-3-27 17:29 | 只看该作者
坐等翻译
发表于 2012-3-27 18:44 | 只看该作者
原帖由 shijiamoni 于 2012-3-27 17:29 发表
坐等翻译
他的意思是电机功率等级是区分飞机等级的标准@( ̄- ̄)@
所以沙发正解
发表于 2012-3-27 18:53 | 只看该作者
1。级别按主轴 到尾尖端长度来算的方法是错的
2 。也有说是按照桨长度来算的 这也是错的
3。 还有说是按照能产生的动力来计算 这也是错的:em15:
关于有刷电机级别来分到还没证实过 现在都是无刷 再这么分还是错的
如果拿电机动力来区分 那么那些拿450用超暴力电机耍的是不是该称为500?
我在把450电机装250上 那是不是250也该叫450了:em15:
[ 本帖最后由 飞狼猫 于 2012-3-27 18:56 编辑 ]
发表于 2012-3-27 19:42 | 只看该作者
就是一个的型号而已,亚拓叫450,雷虎叫325,泰世叫X3。
用有刷电机的型号?有这样的有刷电机型号的吗?700是先有油动还是先有电动的?有有刷的700?
型号是怎样定出来的?桨?电机?轴距?仿别人的?只有厂家自己。
