返回列表 发新帖
楼主: 与世无争
SpEKTRUM DX10T 拆箱圖 - 只看圖,不說話
发表于 2012-4-13 00:58 | 只看该作者
口水哗啦啦…能不能揭秘一下参数,售价…
[ 本帖最后由 416786163 于 2012-4-13 18:50 编辑 ]
 楼主| 发表于 2012-4-13 19:01 | 只看该作者
回复 21楼 416786163 的帖子
# of Channels:
Modulation:
DSM2/DSMX
Band:
2.4GHz
Receiver:
AR10000
Features:
Airplane and Heli
Model Memory:
50
Modes:
Selectable 1,2,3 or 4
Giant-scale bombers, battleships, battle bots - if you're RC passion is off the beaten path the DX10t with X-Plus channel expansion capability* is the 2.4 system for you. Besides giving you the speed and security of DSMX and a wealth of programming features, you get the option of adding 8 extra channels and customizing the interface with different plug-in switch modules. Each switch module optimizes the switch configuration for one of four model types airplanes, helicopters, ships and vehicles. When you plug new switch modules in, the DX10t software will automatically present you with all the necessary menu options needed to use the new switch configuration.
The DX10t will also allow you to switch between Mode 1, 2, 3 and 4 stick configurations without ever having to open the transmitter. You will also enjoy the built-in telemetry and the convenience of an SD card slot that makes it possible to store telemetry data, expand model memory, make updates and share setups with other DX10t users. An AR10000 10-channel DSMX receiver and a 2500mAh LiPo transmitter battery is also included.
* Requires X-Plus channel expansion module sold separately.
价格在RMB 6200左右:em15:
发表于 2012-4-13 20:27 | 只看该作者
好东西
发表于 2012-4-14 21:17 | 只看该作者
很拉风。。。
发表于 2012-4-15 13:45 | 只看该作者
楼主米人。
这个遥控器很漂亮,摇杆很传神,似乎摇杆上可以装按钮,比如弄航拍的时候可以控制快门,很爽。
这控的开关模块好贵的。
发表于 2012-4-15 13:47 | 只看该作者
楼主,发点详细图片吧,我看介绍好像说这个控改手不用拆控就可以的,似乎很高级。还有,你用托盘么,这个造型好像不太适合直接拿手里。
发表于 2012-4-15 19:12 | 只看该作者
专控专用。。板控不是来飞3D的。。。
发表于 2012-4-16 21:39 | 只看该作者
很牛的样子
发表于 2012-4-24 00:20 | 只看该作者
怪物
发表于 2012-4-26 14:06 | 只看该作者
好囧
发表于 2012-4-26 17:15 | 只看该作者
漂亮
发表于 2012-4-26 17:28 | 只看该作者
终于上市了、我的下一个控就准备选这个了:em15: :em15:
