多轴安全降落伞規格
This is a parachute recovery system that is servo operated and is designed to be ran on a two way switch. To avoid electronic mishaps we have determined that entire manual control of the system would be the best course of action.
The base of this unit is designed to be the mount, though other forms of mounting could be adopted. It can be mounted as a motor on an extra motor mount on any boom The base has motor bolt spacing at 3mm x 25mm, 3mm x 32mm, 4mm x 30mm to allow for the most common motor mounts on the market. There is room for you to drill out holes to meet your application if these do not work.
Specifications:
Weight: 11 ounces
Length: 5 1/2 Inches
Cylinder Size: 2 3/8 Inches
Deployment Method: High Energy Compression Spring
Servo: Hitec micro HS-82mg
