绑重物测量的电流等值与实际飞行值误差挺大~
摘引一段www.trextuning.com的测试结果:
“The interesting elements to this flight data are the differences in amp draw in flight versus static bench testing. I knew that the data would show a lower amp draw with the model in free flight rather than strapped down but the surprise is how large this difference turned out to be. The maximum amp draw in flight was 22.3 amps which is significantly lower than the 27 amps pulled in a static carbon blade bench test. Also notable is that the average current for the entire flight was only 8.3 amps. ”
原帖由 dmagic1 于 2005-11-8 13:16 发表
“The interesting elements to this flight data are the differences in amp draw in flight versus static ...
