 今天研究了一下STC在ISP烧程序时,自动冷启动的逻辑。
 用USB转TTL,加上一个电阻和一个8050三极管做的电子开关。成功实现了自动冷启动功能。
 原理:
 jian听上位机串口发来的数据,波特率 2400,如果连续收到若干个(20个) 0x7F 字符,则电子开关给低电平,延时几百ms,再拉高。
 STC89C52 源代码:
 #include "reg51.h"#include "stdio.h"
 #include "intrins.h"
 #define FOSC 16000000L
 #define BAUD 2400
 /*Define UART parity mode*/
 #define NONE_PARITY     0   //None parity
 #define ODD_PARITY      1   //Odd parity
 #define EVEN_PARITY     2   //Even parity
 #define MARK_PARITY     3   //Mark parity
 #define SPACE_PARITY    4   //Space parity
 #define PARITYBIT NONE_PARITY
 sfr T2CON  = 0xC8;          //timer2 control register
 sfr RCAP2L = 0xCA;
 sfr RCAP2H = 0xCB;
 sfr TL2    = 0xCC;
 sfr TH2    = 0xCD;
 sbit PIN1 = P1^0;
 sbit PIN2 = P1^1;
 sbit PIN3 = P1^2;
 unsigned int nCount7F = 0;
 unsigned char lIsRx = 0;
 unsigned char nRxCount = 0;
 bit busy;
 void Sleep(unsigned int nLoop)
 unsigned int i;
 for (; nLoop > 0; nLoop--) for (i = 0; i < 10000; i++);
 void SetUSARTReceiverEnabled()
 ES = 1;
 void SetUSARTReceiverDisabled()
 ES = 0;
 void UARTInit()
 #if (PARITYBIT == NONE_PARITY)
 SCON = 0x50;            //8-bit variable UART
 #elif (PARITYBIT == ODD_PARITY) || (PARITYBIT == EVEN_PARITY) || (PARITYBIT == MARK_PARITY)
 SCON = 0xda;            //9-bit variable UART, parity bit initial to 1
 #elif (PARITYBIT == SPACE_PARITY)
 SCON = 0xd2;            //9-bit variable UART, parity bit initial to 0
 #endif
 TL2 = RCAP2L = -(FOSC/32/BAUD); //Set auto-reload vaule
 TH2 = RCAP2H = (-(FOSC/32/BAUD)) >> 8;
 T2CON = 0x34;           //Timer2 start run
 ES = 1;                 //Enable UART interrupt
 EA = 1;                 //Open master interrupt switch
 void Uart_Isr() interrupt 4
 char cFlag;
 if (RI)
 RI = 0;
 cFlag = SBUF;
 if (cFlag == 0x7F) {
 nCount7F++;
 if (nCount7F > 100) nCount7F = 100;
 } else nCount7F = 0;
 lIsRx = 1;
 if (TI)
 TI = 0;
 busy = 0;
 void main() {
 char nLoop;
 UARTInit();
 nCount7F = 0;
 PIN1 = 0;
 PIN3 = 1;
 for (nLoop = 0; nLoop < 4; nLoop++) {
 PIN2 = 1;
 Sleep(1);
 PIN2 = 0;
 Sleep(1);
 for (;;) {
 if (nCount7F > 30) {
 PIN1 = 1;
 PIN2 = 1;
 PIN3 = 1;
 SetUSARTReceiverDisabled();
 Sleep(20);
 SetUSARTReceiverEnabled();
 PIN1 = 0;
 PIN2 = 0;
 nCount7F = 0;
 nRxCount++;
 if (nRxCount > 200) {
 nRxCount = 0;
 lIsRx = 0;
 if (nRxCount > 100 && lIsRx) {
 PIN3 = 0;
 } else {
 PIN3 = 1;
