原帖由 wangpen596 于 2010-4-14 11:36 发表
你好 我的是8~12S 用 50V 130A 电调 和4025的电机 想改亚拓700电 可以给我个电调的设置参数吗 谢谢 我没玩过电直 麻烦说的详细一些 呵呵
700的直机要用到4035以上电机 或是新款 5020电机
HK-4035 Series Motors
The HK-4035 series of motors is designed for helicopters with 690 to 720mm blades such as the Trex 700E Or for people that want a lot of power in a 600 class machine. There are 3 motors available in this series, for a variety of battery sizes and gearing options. Here is a list of the basic specs for these motors.
HK-4035-500, Kv = 500, Pmax = 2520W, Imax = 60 Amps
HK-4035-560, Kv = 560, Pmax = 2450W, Imax = 70 Amps
HK-4035-630, Kv = 630, Pmax = 2380W, Imax = 85 Amps
The 630Kv motor is designed for operation on 8-10 Li-Po cells, the 560Kv motor is designed for use on 10-12 Li-Po cells, and the 500 Kv motor is for use with 12-14 Li-Po cells, depending on the gearing used and the desired head speed.
电调设定很简单
1.油门行程校正(请在红外线模块上调到PPM位置)
2.决定是否使用定速(请在红外线模块上调到IRS位置),
3.设定电池低电压阀值
搞定
如果需要细部修改个参数请参阅中文说明书
如果需要设定定速功能、也参阅中文说明书(电直定速概念与油机不完全相同、每家设定的方式也不同、在Scorpion的电调当中、各个飞行模式的油门曲线应该都是一水平直线、电机启动与否是以油门保护开关做为切换)
第一次电调记忆电机转速时将螺距都设成0度(不论任何油门位置)、当第一次缓起动结束后、电调便会记忆住电机带上主桨负载后的转速、以后转速要增加或是降低只要调整控里的油门位置就好 |
