3.0.a相对与2.5.v的改进如下: :em15:
New features, Improvements and fixes
• Physics:
__ • Helicopters:
__ __ • New detailed flybarless physics system:
__ ____ • Choose from Standard, Passive flybarless or Active flybarless systems
__ ____ • Adjust advanced parameters such as Agility, Response and Gain
__ ____ • Accurately simulates all low-gain and high-gain flybarless effects such as:
________ • Retreating blade stalls
________ • Grabbing
________ • Wag/bounce
__ ____ • Active flybarless system with fully configurable self-righting behaviour
__ __ • Improved, more accurate flybar physics (e.g. cyclic interaction)
__ __ • Increased stability in pirouetting manoeuvres (e.g. Piro-flips/chaos)
__ __ • Improved tail-rotor wash profiles
__ __ • Improved engine torque/drag curves
__ __ • Added rotor-bearing drag for correct behaviour under autorotations
• Various changes and tweaks to model setups and variants
• User Interface:
__ • New-look user-interface and more themes to choose from
__ • Huge number of User Interface improvements and tweaks
__ • New, easier-to-use Widget UI system
__ • Sort model selection by make, type, etc
__ • Show actual model names and manufacturers in list
__ • Added support for extended character-set languages, e.g Russian/Chinese/etc
__ • Improved translation for all languages
__ • Onscreen indicator for software functions (i.e. rates, idle-up, throttle-hold, etc)
__ • Quick Tips on loading screen
__ • New "Look At" menu under the "View > Camera" menu makes spectating easier
• Launch options:
__ • Set your preferred launch method for each model
__ • Choose from:
__ __ • Ground launch - for powered models
__ __ • Hand launch - new hand-launch system controlled from your radio
__ __ • Tow launch - have an AI-controlled pilot tow your glider into the air
• Widgets:
__ • New Timer widget
__ • New logbook widget
__ • Improved onscreen transmitter display
• Improved model > Edit screen:
__ • Simple and Detailed views
__ • Easy "Model Setup" control lets you change a model's general setup
__ • Clearer editable parameter list
__ • More description on editable attributes
__ • Scale Wizard helps you resize models more easily
• New toolbar system for more streamlined interface:
__ • Notifications bar
__ • Favourites bar
__ • Inflight tuning bar
• Graphics:
__ • Pilots on all model types (planes, helicopters, autogyros, tilt-rotors)
__ • Multiple pilots on models
__ • Fixed moving tail and nose wheels
__ • New water-spray effects
__ • Improved and optimised water wakes and splashes
__ • Improved smoke system
__ • Extra camera zoom option for smaller models
__ • Improved mouse-wheel zooming
• Controls:
__ • New software low-rates control for all model types
__ • New control profiles added
• Buddies:
__ • Fly with up to 3 computer-controlled pilots
__ • Set their skill level and model choice
__ • Intelligent AI avoids you and flies in a realistic manner
__ • Spectate a buddy and learn from their control movements
• Online:
__ • More advanced lobby and lobby-chat
__ • Select your own avatar and see other pilots' avatars online
__ • Filter models - choose only to fly with certain model types
__ • Messenger widget replaced with Multiplayer Toolbar:
__ __• Enhanced chat
____ • Easier control for hosts
• Competitions:
__ • All modes revamped with better graphics, user-interfaces and competition logic
__ • New competition system:
____ • New "challenge" mode
___ _• Keep your top scores
___ _• Online and offline play
___ _• Clear, easier user-interface and controls
__ • New Laser Combat mode added
• Layouts:
__ • Improved layout graphics
__ • More layouts added
• Improved update system:
__ • Improved, clearer update browser
__ • New updates shown more easily
__ • Icons for updates
__ • Seperate program update system |
