查看: 2632|回复: 0
PX4官网调参指导英文翻译加注释 接上一贴 外文部分
发表于 2015-7-5 22:57 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Multirotor PID Tuning Guide
NEVER do multirotor tuning with carbon fiber or carbon fiber reinforced blades. NEVER use damaged blades.
For SAFETY reason, the default gains are set to small value. You HAVE TO increase the gains before you can expect any control responses.
This tutorial is valid for all multi rotor setups (AR.Drone, PWM Quads / Hexa / Octo setups). Proportional, Integral, Derivative controllers are the most widespread control technique. There are substantially better performing control techniques (LQR/LQG) from the model predictive control, since these techniques require a more or less accurate model of the system, they not as widely used. The goal of all PX4 control infrastructure is move as soon as possible on MPC, since not for all supported systems models are available, PID tuning is very relevant (and PID control sufficient for many cases).
Introduction
The PX4 multirotor_att_control app executes an outer loop of orientation controller, controlled by parameters:
Roll control (MC_ROLL_P)
Pitch control (MC_PITCH_P)
Yaw control (MC_YAW_P)
And an inner loop with three independent PID controllers to control the attitude rates:
Roll rate control (MC_ROLLRATE_P, MC_ROLLRATE_I, MC_ROLLRATE_D)
Pitch rate control (MC_PITCHRATE_P, MC_PITCHRATE_I, MC_PITCHRATE_D)
Yaw rate control (MC_YAWRATE_P, MC_YAWRATE_I, MC_YAWRATE_D)
The outer loop's output are desired body rates (e.g. if the multirotor should be level but currently has 30 degrees roll, the control output will be e.g. a rotation speed of 60 degrees per second). The inner rate control loop changes the rotor motor outputs so that the copter rotates with the desired angular speed.
The gains actually have an intuitive meaning, e.g.: if the MC_ROLL_P gain is 6.0, the copter will try to compensate 0.5 radian offset in attitude (~30 degrees) with 6 times the angular speed, i.e. 3 radians/s or ~170 degrees/s. Then if gain for the inner loop MC_ROLLRATE_P is 0.1 then thrust control output for roll will be 3 * 0.1 = 0.3. This means that it will lower the speed of rotors on one side by 30% and increase the speed on the other one to induce angular momentum in order to go back to level.
There is also MC_YAW_FF parameter that controls how much of user input need to feed forward to yaw rate controller. 0 means very slow control, controller will start to move yaw only when sees yaw position error, 1 means very responsive control, but with some overshot, controller will move yaw immediately, always keeping yaw error near zero.
Motor Band / Limiting
As the above example illustrates, under certain conditions it would be possible that one motor gets an input higher than its maximum speed and another gets an input lower than zero. If this happens, the forces created by the motors violate the control model and the multi rotor will likely flip. To prevent this, the multi rotor mixers on PX4 include a band-limit. If one of the rotors leaves this safety band, the total thrust of the system is lowered so that the relative percentage that the controller did output can be satisfied. As a result the multi rotor might not climb or loose altitude a bit, but it will never flip over. The same for lower side, even if commanded roll is large, it will be scaled to not exceed commanded summary thrust and copter will not flip on takeoff at near-zero thrust.
Step 1: Preparation
First of all set all parameters to initial values:
Set all MC_XXX_P to zero (ROLL, PITCH, YAW)
Set all MC_XXXRATE_P, MC_XXXRATE_I, MC_XXXRATE_D to zero, except MC_ROLLRATE_P and MC_PITCHRATE_P
Set MC_ROLLRATE_P and MC_PITCHRATE_P to a small value, e.g. 0.02
Set MC_YAW_FF to 0.5
All gains should be increased very slowly, by 20%-30% per iteration, and even 10% for final fine tuning. Note, that too large gain (even only 1.5-2 times more than optimal!) may cause very dangerous oscillations!
Step 2: Stabilize Roll and Pitch Rates
P Gain Tuning
Parameters: MC_ROLLRATE_P, MC_PITCHRATE_P.
If copter is symmetrical, then values for ROLL and PITCH should be equal, if not - then tune it separately.
Keep the multi rotor in your hand and increase the thrust to about 50%, so that the weight is virtually zero. Tilt it in roll or pitch direction, and observe the response. It should mildly fight the motion, but it will NOT try to go back to level. If it oscillates, tune down RATE_P. Once the control response is slow but correct, increase RATE_P until it starts to oscillate. Cut back RATE_P until it does only mildly oscillate or not oscillate any more (about 10% cutback), just over-shoots. Typical value is around 0.1.
D Gain Tuning
Parameters: MC_ROLLRATE_D, MC_PITCHRATE_D.
Assuming the gains are in a state where the multi rotor oscillated and RATE_P was slightly reduced. Slowly increase RATE_D, starting from 0.01. Increase RATE_D to stop the last bit of oscillation. If the motors become twitchy, the RATE_D is too large, cut it back. By playing with the magnitudes of RATE_P and RATE_D the response can be fine-tuned. Typical value is around 0.010.02.
In QGroundControl you can plot roll and pitch rates (ATTITUDE.rollspeed/pitchspeed). It must not oscillate, but some overshot (10-20%) is ok.
I Gain Tuning
If the roll and pitch rates never reach the setpoint but have an offset, add MC_ROLLRATE_I and MC_PITCHRATE_I gains, starting at 5-10% of the MC_ROLLRATE_P gain value.
Step 3: Stabilize Roll and Pitch Angles
P Gain Tuning
Parameters: MC_RATE_P, MC_RATE_P.
Set MC_ROLL_P and MC_PITCH_P to a small value, e.g. 3
Keep the multi rotor in your hand and increase the thrust to about 50%, so that the weight is virtually zero. Tilt it in roll or pitch direction, and observe the response. It should go slowly back to level. If it oscillates, tune down P. Once the control response is slow but correct, increase P until it starts to oscillate. Optimal responce is some overshot (~10-20%). After getting stable respone fine tune RATE_P, RATE_D again.
In QGroundControl you can plot roll and pitch (ATTITUDE.roll/pitch) and control (ctrl0, ctrl1). Attitude angles overshot should be not more than 10-20%.
Step 4: Stabilize Yaw Rate
P Gain Tuning
Parameters: MC_YAWRATE_P.
Set MC_YAWRATE_P to small value, e.g. 0.1
Keep the multi rotor in your hand and increase the thrust to about 50%, so that the weight is virtually zero. Turn it around its yaw axis, observe the response. The motor sound should change and the system should fight the yaw rotation. The response will be substantially weaker than roll and pitch, which is fine. If it oscillates or becomes twitchy, tune down RATE_P. If responce is very large even on small movements (full throttle spinning vs idle spinning propellers) reduce RATE_P. Typical value is around 0.20.3.
The yaw rate control, if very strong or oscillating, can deteriorate the roll and pitch response. Check the total response by turning around, roll, pitch and yaw.
Step 5: Stabilize Yaw Angle
P Gain Tuning
Parameters: MC_YAW_P.
Set MC_YAW_P to a low value, e.g. 1
Keep the multi rotor in your hand and increase the thrust to about 50%, so that the weight is virtually zero. Rotate it around yaw, and observe the response. It should go slowly back to the initial heading. If it oscillates, tune down P. Once the control response is slow but correct, increase P until the response is firm, but it does not oscillate. Typical value is around 23.
Look at ATTITUDE.yaw in QGroundControl. Yaw overshot should be not more than 2-5% (less than for attitude).
Feed Forward Tuning
Parameters: MC_YAW_FF.
This parameter is not critical and can be tuned in flight, in worst case yaw responce will be sluggish or too fast. Play with FF parameter to get comfortable responce. Valid range is 01. Typical value is 0.80.9. (For aerial video optimal value may be much smaller to get smooth responce.)
