查看: 878|回复: 1
同样是FUTABA为什么人家飞4.2KM?
发表于 2015-8-7 11:45 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
我飞T10J 800米左右就报警了 可是人家在湖南飞4.2KM自动失控返航?求解啊!有图有真相 人家也没有说用增程啊!
2015年1月6日发布
MFD (My Fly Dream) MTD (My Twin Dreams) is the new MFD long Range FPV plane. This twin motor power plane simply beats all the FPV planes out there in market when it comes to flight performance, flight endurance and long range flight capabilities. With a tested 84 minutes flight endurance with a single 4S 16000mAh battery, this plane can go places. 30 to 40km is not a big issue. It cruises at a very good speed keeping battery mAh usage low thanks to its dual efficient motors and offers ample power and speed when pilot needs it.
Coupled with MFD autopilot and MFD AAT, My Twin Dream simply turns into an obedient and long range flying puppy of yours. MFD Autopilot is so feature rich that I decided to do a separate video on this autopilot.
It was my MTD’s Maiden flight and I thought it was a good time to test my Stock Futaba T10J 2.4Ghz Radio System range. Amazingly I went 4.2km when MFD Autopilot Activated RTH and brought my MTD home safely.
Enjoy the Ground cam and On board GoPro video of this flight. Now that I am back home to Zhuzhou, I have done many more flights on MTD and will be posting the videos soon.
视频地址(需翻墙):https://www.youtube.com/watch?v=i1SrPCPtVJI
+ABMNS PRODUCTION A good step up from T8J is T8FG (14 Channel Digital) Radio. But I suggest you try 14SG. Once you have your hands on 14SG, you won't like other radios in this price range. 14 Channels, ability to bind more than one Rx. SBUS 1 and 2, R7008SB is a versatile Rx too. Telemetry (with sensors of course), model saving and transfer using SD card. and much more features of programming. Specially the one where you can slow down a servo to move it smooth :D, Throttle delay that makes EDF work just like real turbine. And the great 4.5 to 5+km Range. I bet in the open its more than 6km or so on 14SG because i get 4.5+km in my city on 14SG. I bet if i try it same place in Guangzhou I will go 6+km
发表于 2015-8-7 12:14 | 只看该作者
路过
