查看: 1295|回复: 6
求个K110 D10用的设置文件~
发表于 2017-2-18 14:31 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
我自己设的总感觉飞着怪怪的 不知道哪里不对
附上我自己的 大家帮我看看~
name=XK K110
mixermode=Advanced
[radio]
protocol=S-FHSS
num_channels=8
tx_power=100mW
[protocol_opts]
Freq-Fine=51
Freq-Coarse=0
[channel1]
template=expo_dr
[mixer]
src=AIL
dest=Ch1
curvetype=expo
points=30,30
[mixer]
src=AIL
dest=Ch1
switch=AIL DR0
scalar=70
curvetype=expo
points=30,30
[channel2]
template=expo_dr
[mixer]
src=ELE
dest=Ch2
curvetype=expo
points=30,30
[mixer]
src=ELE
dest=Ch2
switch=AIL DR0
scalar=70
curvetype=expo
points=30,30
[channel3]
safetysw=Virt1
safetyval=-100
template=expo_dr
[mixer]
src=THR
dest=Ch3
curvetype=7point
points=-100,-66,-33,0,33,66,100
[mixer]
src=THR
dest=Ch3
switch=MIX1
curvetype=7point
points=85,80,80,80,80,80,85
[mixer]
src=THR
dest=Ch3
switch=MIX2
curvetype=7point
points=100,95,95,95,95,95,100
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=ELE DR1
dest=Ch5
curvetype=expo
points=0,0
[channel6]
scalar=60
template=expo_dr
[mixer]
src=THR
dest=Ch6
curvetype=3point
points=-30,0,100
[mixer]
src=THR
dest=Ch6
switch=MIX1
curvetype=3point
points=-100,0,100
[mixer]
src=THR
dest=Ch6
switch=MIX2
curvetype=3point
points=-100,0,100
[virtchan1]
name=T Hold
template=complex
[mixer]
src=Virt1
dest=Virt1
usetrim=0
curvetype=min/max
points=0
[mixer]
src=THR
dest=Virt1
offset=-1
usetrim=0
muxtype=add
[mixer]
src=AIL
dest=Virt1
switch=RUD DR0
usetrim=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=!Virt1
time=300
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
Model=1,11
V-trim=55,11,1
H-trim=2,59,3
V-trim=69,11,2
H-trim=77,59,4
Small-box=77,6,None
Small-box=4,47,Timer1
Bargraph=79,30,Ch3
Bargraph=85,30,Ch4
Bargraph=91,30,Ch2
Bargraph=97,30,Ch1
Bargraph=103,30,Ch5
Bargraph=109,30,Ch6
Bargraph=115,30,Ch7
Bargraph=121,30,Ch8
Toggle=78,16,233,235,0,RUD DR
Toggle=90,16,195,194,0,ELE DR
Toggle=104,16,253,255,225,MIX
Toggle=116,16,6,69,0,AIL DR
Battery=102,1
TxPower=75,1
quickpage1=Model setup
quickpage2=Mixer
quickpage3=Channel monitor
quickpage4=Telemetry monitor
发表于 2017-2-18 16:10 | 只看该作者
发表于 2017-2-18 16:12 | 只看该作者
这是  d7e刷devation5设置的110跟设置mcpx的方式基本一致 . 你可以参考一下
发表于 2017-2-18 16:13 | 只看该作者
没有提到的都默认
发表于 2017-2-18 16:15 | 只看该作者
最后到mixer把下面的改一下
发表于 2017-2-18 16:16 | 只看该作者
 楼主| 发表于 2017-2-18 17:31 | 只看该作者
谢谢 晚上我去试试~
