查看: 15492|回复: 83
【2018.9.3更新】【TBS Crossfire相关】---包含与TBS Crossfire相关的大部分内容
发表于 2017-10-15 23:24 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
好久没发帖了~~~
随着最近国外视频中TBS Crossfire的出镜率增高,我整理了Youtube中
KrazyFPV对TBS Crossfire的相关视频,基本包含了对码、升级固件、天线摆放、RSSI设置等大部分内容。(本帖后续不定时更新!)
英语较差的模友可登陆Youtube搜索]Krazy FPV,观看带字幕翻译的原视频。
1、两种接收机天线的固定、简版Crossfire&BF&X9D的设置
2、用X9D SD卡中的LUA对码和设置
3、
Crossfire V2接收机&KissFC的连接和在KissGUI中的设置
4、
Crossfire 接收机固件的升级
5、Crossfire接收机对码
6、映射输出通道
7、如何用TBS Crossfire在BF的OSD里设置出信号强度或者RSSI
8、V2接收天线的最佳极化
9、RSSI / Link Quality (LQ) Warning for OpenTX
TBS Crossfire – LQ monitoring
While you are flying it´s important to have a eye on your rc link.
If you are not using a osd there is a alternativ way to get noticed – with voice warnings from your taranis.
Requirements:
  • aranis x9d(+)/ X7/ x10
  • OpenTX 2.2 (or higher)
  • Crossfire 1.65 (or higher)
  • Crossfire receiver with enabled telemetry
  • If you have problems with the crsf telemetry
Information
The Crossfire can output the LQ with wider ranger (0-300%) which can´t be interpreted by OpneTX.
Therefore the splitet it in to two sensors: RLQY and RFMD.
  • RLQY: Received link quality - the ammount of the transmittet signal recived by the reciver
  • RFMD: Received frequenzy mode - to scale the 300% Crossfire LQ down to 3x 100%
RFMD 2 = 150Hz Mode
RFMD 1 = 50Hz Mode
RFMD 0 = 4Hz Mode (forced telemetry)
LQ = 0-100%
While the Crossfire is in 150Hz mode the lq doesn´t matther so there s no need to monitore the link quality. When it switches to the 50Hz mode the critical level is at 70%.
Setup
The setup for the radio is relay simple:
What they mean:
L01: Monitors the Crossfire frequency mode, activated when it´s not in 150Hz mode
L02: Activ when the Link quality drops below 80% (pre warning) AND 50 or 4 Hz mode is activ
L03: Same as L02 but with the critical warning level at 70%
L02 and L03 also got a smal delay (0.5s) to avoid warnings when the signal is only bad for a short moment.
With the logical switches the voice alerts will be triggert every time the are activ.
What they mean:
SF1: when L02 is activ, plays the selected track ones -but not at the startup
SF2: same as SF1 for the critical warning
Why to use Link quality instead of RSSI?
LQ is much more easy to monitor than RSSI. To knwo the range limit based on RSSI the noise floor need to be known as well. Noise floor depends on environment and on the components built-in the airframe. If you are not so familiar how RSSI works we recommend to use LQ.
更新RF飞控+crossfire的接线图
今后本帖将不定时更新搬运Crossfire相关视频!敬请关注!
发表于 2017-10-16 10:56 | 只看该作者
TBS Crossfire天线放置有要求(树立固定),在穿越机上适合使用么?
发表于 2017-10-16 19:58 | 只看该作者
看油管介绍,穿越机天线安装有特别要求:
发表于 2017-10-16 21:26 | 只看该作者
多大点天线放置的视频照片,楼主
 楼主| 发表于 2017-10-16 21:29 | 只看该作者
适合啊   crossfire玩穿越的非常多啊
发表于 2017-10-16 23:44 | 只看该作者
翻滚状态,信号死点不少。
 楼主| 发表于 2017-10-17 08:32 | 只看该作者
数不清 发表于 2017-10-16 23:44
翻滚状态,信号死点不少。
所以视频告诉你怎么放置能保证死点最少
发表于 2017-10-18 12:16 | 只看该作者
逼格高啊,感觉穿越没啥用
发表于 2017-10-18 12:38 | 只看该作者
xgs610 发表于 2017-10-17 08:32
所以视频告诉你怎么放置能保证死点最少
发觉这货适合远程平稳飞行,适合三角翼。
发表于 2017-12-12 18:42 | 只看该作者
所以视频告诉你怎么放置能保证死点最少
穿越机用TBS Crossfire Micro TX是不是性价比更好,说是能覆盖10KM,日常使用要是覆盖一半距离都够了。
 楼主| 发表于 2017-12-18 17:35 | 只看该作者
体积小,方便安装,价格低,距离也够,穿越机首选
发表于 2017-12-20 10:28 | 只看该作者
Cross fire Micro TX到手杯具,配合X7没法用,用Crossfire脚本能侦测到设备,但点击确认下一步就白屏没显示,X7屏幕没有任何信息显示,只有返回上一级菜单。
X7已经升级2.2.1RC3并刷每天 nightlies N462版,都是一样状况,SD卡Crossfire 脚本文件是最后一个ZIP包 (2.2V0013)。
Micro TX出厂固件是2.06,到手第一步用TBS Agent升级到了2.11。
期间控复位多次,刷不同版本,最终情况还是一样,MicroTX现在寄回商家测试。
知道X7有对TBS Crossfire数据回传有缺陷,按理说不影响操作使用,难道这个Micro TX是坏的?
发表于 2017-12-20 15:05 | 只看该作者
数不清 发表于 2017-12-20 10:28
Cross fire Micro TX到手杯具,配合X7没法用,用Crossfire脚本能侦测到设备,但点击确认下一步就白屏没显 ...
换X10S吧
发表于 2017-12-20 16:38 | 只看该作者
那我还不如入TBS 自家的Tango,自带图像接收不说,和自家的发射机完美使用。
发表于 2017-12-20 18:17 | 只看该作者
tango屏幕真的渣渣 亮度也不行 手感也是渣渣
发表于 2017-12-20 21:43 | 只看该作者
那屏幕应急还可以
发表于 2018-1-15 18:47 | 只看该作者
兄弟在吗?我入了TBS Crossfire Micro915高频头,我黑羊控,我把高频头里面的region (OPEN)选项改成了FCC后这个选项就没了?而且我重刷高频头固件也不出来了,固件是2.12,刷2.11也一样。在这里求助下,咋样把高频头设置还原??
发表于 2018-1-15 21:25 | 只看该作者
hcc 发表于 2018-1-15 18:47
兄弟在吗?我入了TBS Crossfire Micro915高频头,我黑羊控,我把高频头里面的region (OPEN)选项改成了FCC后 ...
试试在另外一个控上插入高频头,看能否修改设置。
发表于 2018-1-15 21:27 | 只看该作者
Cross fire Micro TX终于可以使用,按照网上教程MOD X7,控固件也升级到了2.2.1正式版,信号接入完美,搭配SmartAudio。
发表于 2018-1-15 21:40 | 只看该作者
我是TANGO控,后来换成X9D里面看也没这选项了。。。。。
