查看: 1096|回复: 5
DEVO10刷deviation V5.0固件后设置250pro、F210 3d和小瓢虫V2的设置文件分享
发表于 2018-3-14 19:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
从DEVO10刷deviation V5.0固件后一直摸索如何设置华科尔250pro、F210 3D及小瓢虫V2版,现在终于好了,分享一下出来,错的请指教。下面文件直接复制到model目录下对应的文件即可。下面一共三个的按需要复制对应的就好。
name=R250 pro
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=8
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
reverse=1
max=100
min=-100
template=expo_dr
[mixer]
src=MIX0
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=MIX0
dest=Ch5
switch=MIX1
scalar=0
curvetype=expo
points=0,0
[mixer]
src=MIX0
dest=Ch5
switch=MIX2
curvetype=expo
points=0,0
[channel6]
reverse=1
template=expo_dr
[mixer]
src=FMODE0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE1
scalar=0
curvetype=expo
points=0,0
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE2
curvetype=expo
points=0,0
[channel7]
reverse=1
template=simple
[mixer]
src=GEAR0
dest=Ch7
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
quickpage4=None
        name=F210 3D
mixermode=Advanced
type=plane
[radio]
protocol=DEVO
num_channels=8
tx_power=100mW
[protocol_opts]
Telemetry=On
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
reverse=1
max=100
min=-100
template=expo_dr
[mixer]
src=MIX0
dest=Ch5
curvetype=expo
points=0,0
[mixer]
src=MIX0
dest=Ch5
switch=MIX1
scalar=0
curvetype=expo
points=0,0
[mixer]
src=MIX0
dest=Ch5
switch=MIX2
curvetype=expo
points=0,0
[channel6]
reverse=1
template=expo_dr
[mixer]
src=FMODE0
dest=Ch6
curvetype=expo
points=0,0
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE1
scalar=0
curvetype=expo
points=0,0
[mixer]
src=FMODE0
dest=Ch6
switch=FMODE2
curvetype=expo
points=0,0
[channel7]
reverse=1
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
        name=ladybird
mixermode=Advanced
[radio]
protocol=DEVO
num_channels=8
tx_power=10mW
[protocol_opts]
Telemetry=On
[channel1]
template=simple
[mixer]
src=ELE
dest=Ch1
[channel2]
template=simple
[mixer]
src=AIL
dest=Ch2
[channel3]
template=simple
[mixer]
src=THR
dest=Ch3
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
reverse=1
[channel6]
reverse=1
[channel7]
reverse=1
template=simple
[mixer]
src=FMODE0
dest=Ch7
curvetype=expo
points=0,0
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer2]
type=countdown
time=10
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Model=75,20
Battery=102,1
TxPower=102,7
发表于 2018-3-14 21:16 | 只看该作者
有点复杂
发表于 2018-3-14 21:52 | 只看该作者
一直不敢刷固件呀,担心弄死
发表于 2018-3-15 03:40 | 只看该作者
oudz 发表于 2018-3-14 21:52
一直不敢刷固件呀,担心弄死
刷不死的,放心,我也有boot文件,哈哈哈
发表于 2018-4-7 21:14 | 只看该作者
非常感谢楼主啊,刚刚刷了5.0,小瓢虫就对不上频了,用了你的代码马上ok
能不能说说为什么正常方式对不上呢?另外,对上频后,设置固定id后又不行了,只能不用固定id
刚刚看到这个帖子,5楼给出了方法,固定id的问题已经解决
RX601接收机不能固定对码?
http://bbs.5imx.com/forum.php?mo ... &fromuid=336509
 楼主| 发表于 2018-4-12 21:41 | 只看该作者
能不能说说为什么正常方式对不上 ...
对,是没办法固定的。
