查看: 1397|回复: 1
有没有厂家作这两个电子设备。
发表于 2006-12-11 11:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Automatic Leveling Control  (水平控制仪)
Measuring only .75" X 1.1" X 0.3", APC-4 is the smallest and yet the most capable, user friendly, automatic leveling control available. Based on 25 years of "hands on" research and development, APC-4 is arguably the best there is. Simple installation, intuitive adjustment which allows fine tuning to meet your own boat's needs, variable sensitivity and it's able to "stand alone" (no signal input required) so you don't have to waste a channel unnecessarily. The incredibly small size allows installation in even the smallest boats, the tightest compartments.
Automatic Depth Control   (深度控制仪)
Combining a state-of-the-art pressure sensor with microprocessor control, ADC - 1 (Automatic Depth Control) will do for depth control what the APC has done for leveling control. Now you can keep your boat at periscope depth all day long! Want to run deeper? Just push the stick forward. ADC - 1 features proportional servo control, the ability to maintain any depth up to 4 feet, can be turned on/off from the  transmitter, easy installation, and small size (1 1/2" x 1 1/2" x 3/4").
Can be connected to either bow or stern planes.
Note: An Automatic Leveling control is required for proper operation.
连接在这里。主要为了潜艇模型用的。
http://www.mikessubworks.com/subs_only.html
发表于 2006-12-12 16:12 | 只看该作者
水平的用水银开关就可以了
深度的么 用个压力传感器 根据 F = P × S 计算出来压强 然后算出来多深 呵呵
很easy的东西
