查看: 730|回复: 0
是G1的OEM版吗?
发表于 2007-1-14 17:43 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://www.helihobby.com/html/helicopter_chargers.html#PARTCSRPB14
[size=-1][size=-1]CSR Li-Poly Balancing Charger
[size=-1][size=-2]Powered by 12V power source
[size=-1]
[size=-1]
[size=-1]
[size=-1]
[size=-1]The only safe way to use Lithium Polymer batteries is to keep your multi-cell pack in balance. CSR Li-Poly Balancing Charger will handle 1-4 cell packs and eliminate the danger of over-charging out-of-balance packs. Charging (from 0.5 - 2.0 amps) and balancing take place simultaneously. Input voltage is 11.5 - 14 volts. This charger has a fuse and cooling fan to insure long life for the internal electronic components. Two 7.4 volt (2 cell) packs can be charged and balanced at the same time. Additional connectors with wire leads are supplied so you can charge any brand of battery.
[size=-1]89.95
[size=-1][size=-2]PART#CSRPB14
[size=-1][size=-2]- With hooks for Balancing leads
- Balancer / Charger in one
- Accurate analog readout
[size=-1][size=-2]
[size=-2]diagram with two 7.4 packs
