Wangki 发表于 2019-9-28 22:15
并没有这个选项,这个servo update rate的值也只能从50-400之间,调的时候接收机并不会丢失信号
富斯的频率微调要在四合一源码里开启重新编译才有的,CH15就是频率微调,源码部分
/** A7105 Fine Frequency Tuning **/
//This is required in rare cases where some A7105 modules and/or RXs have an inaccurate crystal oscillator.
//If using Serial mode only (for now), you can use CH15 to find the right tuning value. -100%=-300, 0%=default 0, +100%=+300.
//Uncomment the line below (remove the "//") to enable this feature.
//#define USE_A7105_CH15_TUNING
_Config.h文件里
