查看: 4643|回复: 38
无意中发现的 居然还真有人做出来了
发表于 2022-5-10 20:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Main Features
1, The single propeller is designed without flaps, which has high efficiency and good wind resistance.
2. The 6-axis electronic gyroscope is added to stabilize the height, and the barometer is added to fix the height, the optical flow positioning, the 720P wide-angle camera, and the image transmission is clear (the remote control helicopter and the optical flow positioning are used for the first time). The flight is more stable and 3, easy to operate! Super long battery life! Impact resistant!
3, The battery life of C127 can reach about 15 minutes
Function:
1; Aileronless design, the propeller is designed based on aerodynamic principles to provide strong power and self-stability of the body. Simple 4-channel design, ultra-stable flight with 6-axis gyroscope;
2; The remote control of the main seat, the feel is delicate, and the control is more accurate;
3; barometer height, optical flow positioning, stable flight;
4; Modularized battery, intelligent power management system, power indicator, convenient and quick installation, effective protection of the battery, longer service life;
5; stunt actions such as ascending, descending, forward, backward, left flying, right flying, left rotation, right rotation, route flight, and pot brushing;
6; 6G mode, using 6-axis gyroscope, stable flight, especially suitable for beginners to fly;
7; Low voltage alarm, locked rotor protection, runaway protection, large and small rudder volume conversion, one-key take-off, one-key landing and other functions;
8; Equipped with a dedicated USB charger, fast and stable charging;
Packing list:
Helicopter*1,
Remote control*1,
Manual*1,
USB charger*1,
Main propeller*2,
Tail propeller*1,
3.7V 580mah lithium battery*1,
Screwdriver*1,
Hexagon wrench*1.
发表于 2022-5-10 20:23 | 只看该作者
这下好了。看不懂了。翻译翻译。主要特点
1 、单桨无襟翼设计,效率高、抗风性能好。
2.加了 6 轴电子陀螺仪来稳定高度,加了气压计来固定高度,光流定位, 720P 广角摄像头,图像传输清晰(首次使用遥控直升机和光流定位)。飞行更稳定 3 、操作方便!超长续航!抗冲击!
3 、 C127 电池的使用寿命可以达到 15 分钟左右
职能:
1 ;无副翼设计,螺旋桨是根据空气动力学原理设计的,提供强大的动力和机体的自稳定性。简单的 4 通道设计, 6 轴陀螺仪超稳定飞行;
2 ;主座椅的遥控器,手感细腻,操控更精准;
3 ;晴雨表高度,光流定位,稳定飞行;
4 、模块化电池,智能电源管理系统,电量指示,安装方便快捷,有效保护电池,使用寿命更长;
5 、上升、下降、前进、后退、左飞、右飞、左转、右转、航线飞行、刷锅等特技动作;
6 ; 6G 模式,采用 6 轴陀螺仪,飞行稳定,特别适合初学者飞行;
7 、低压报警、锁定旋翼保护、失控保护、大小舵音量转换、一键起飞、一键式降落等功能;
8 ;配备专用 USB 充电器,充电快速稳定;
装箱单:
直升机* 1
遥控器* 1 ,
手动* 1 ,
USB 充电器* 1 ,
主螺旋桨* 2
尾螺旋桨* 1 ,
3.7 V 580 ma ma 锂电池* 1 ,
螺丝刀* 1 ,
内六角扳手* 1 。
发表于 2022-5-10 20:38 | 只看该作者
这玩意儿被媒体吹的神乎其神
 楼主| 发表于 2022-5-10 20:47 | 只看该作者
问题是没见过正品行货是什么样子的,
发表于 2022-5-10 20:51 | 只看该作者
小丛 发表于 2022-5-10 20:47
问题是没见过正品行货是什么样子的,
这是那个网站的,淘宝的要9百多
发表于 2022-5-10 21:01 | 只看该作者
军用的好贵
发表于 2022-5-10 21:08 | 只看该作者
屈宪宪 发表于 2022-5-10 20:23
这下好了。看不懂了。翻译翻译。主要特点
这是人工翻译吗?
发表于 2022-5-10 21:27 | 只看该作者
哪里有卖?
发表于 2022-5-10 21:29 | 只看该作者
300内性价比就OK了。
 楼主| 发表于 2022-5-10 21:31 | 只看该作者
在   某宝看见的
 楼主| 发表于 2022-5-10 21:32 | 只看该作者
归墟使者 发表于 2022-5-10 20:51
这是那个网站的,淘宝的要9百多
你搜上边的 关键字。。有两家在卖   另一家就是截图那个
发表于 2022-5-10 21:38 | 只看该作者
我们都给他山寨出来N多版本。。。
 楼主| 发表于 2022-5-10 21:52 | 只看该作者
二农戏猪 发表于 2022-5-10 21:38
我们都给他山寨出来N多版本。。。
发表于 2022-5-10 22:10 | 只看该作者
900多不贵啊,有没有飞行视频和详细介绍,还真想买一个玩玩。
不过看照片尾电机应该是有刷的,老美那个“黑色大黄蜂”是无刷的,而且主旋翼带翼形,说明不是靠变螺距改变升力,是四通道的翼形,不抗风。
老美的主旋翼也是带翼形
应该是无刷尾电机
发表于 2022-5-10 22:45 | 只看该作者
你那个价格很便宜哦
发表于 2022-5-10 22:48 | 只看该作者
发表于 2022-5-11 01:22 | 只看该作者
闲鱼上已经有人在卖了
发表于 2022-5-11 04:25 | 只看该作者
 楼主| 发表于 2022-5-11 13:21 | 只看该作者
Andika 发表于 2022-5-11 04:25
http://www.gforce-hobby.jp/products/GB200.html
官网都有????
发表于 2022-5-11 15:33 | 只看该作者
wifi图传,距离很近,没有云台  很晕  当个玩具挺好的
