![](http://photo.5imx.com/up/0706/02/20076281247370.jpg)
The millennium model of the M-14 is now standard equipment with electric trim, Flydat or EIS engine monitor, altimeter, airspeed indicator, rotor tachometer, prerotator, rotor brake, wheel brakes, landing light, and wheel pants. See the extensive list of standard equipment listed below. Two different engines are available: Rotax 914 turbo (115hp) or Rotax 912 ULS (100hp). With the Rotax 912 ULS, carburetor heat and temperature gauge is standard. The M14 Scout, with compact seating and aerodynamic design, afford exceptional performance and two-seat utility with the essential Magni features of safety, stability, reliability and superior structural strength. The M14 is Magni's sporting model, but you can share the fun with a companion too!
![](http://photo.5imx.com/up/0706/02/20076281247371.jpg)
Technical data for Magni M-14 Scout 2000
Rotor diameter: 8.23m, overall length: 3.95m, overall width: 1.80m, overall height: 2.50m, propeller diameter: 1.70m, weight empty: 248kg, max take-off weight: 550kg, max level speed: 185km/h, cruising speed: 145km/h, rate of climb at sea level: 5m/s, service ceiling: 3500m, take-off run: 70m, landing run: 0-30m, range, no reserves: 305km, endurance: 2.1h |
