查看: 1765|回复: 5
JR 12X 2.4GHz DSM2 的最新消息
发表于 2008-1-22 14:15 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跳票半年的JR 12X 2.4GHz DSM2,最近又有了些新消息,据说是快了
JR’s phenomenal 12X. The ultimate combination of pro-class performance, security, convenience and quality.As a product of inspired collaboration between JR and Spektrum engineers, the integrated 12X 2.4 and module-based 12X MV represent a true breakthrough in pro-class radio control. So in addition to flying with the proven security and convenience of Spektrum™ 2.4GHz DSM® technology, you can expect to be flying with the kind of innovative, no-nonsense features you expect from JR®––features devoted solely to the experience of flying with optimized control of your models.
Ultra-fast 2.4GHz DSM2 control response, plus refined 2048 resolution.The extreme low latency of the 12X––a result of JR/Spektrum cooperation and ingenuity––will deliver an astonishing sense of connection with your model. It’s a feature that prompted perennial World Championship competitor Quique Somenzini to declare the prototype 12X he tested “unbelievable, amazing!” after only one flight. Also, thanks to another 12X breakthrough, all 12 channels will respond to commands with identical speed and perfect synchronization for unprecedented control precision. This instantaneous response is further complemented by the accuracy of JR’s refined 2048 resolution.
Transition to 2.4GHz RC at your pace.Although a number of fliers will choose to re-equip all of their models with 2.4GHz receivers right away, others may prefer to make their transition to 2.4GHz RC more gradual by flying with a mix of 72MHz and 2.4GHz-equipped models. And that’s why JR will offer the 12X transmitter in 2 variants—the dedicated, integrated 2.4GHz 12X 2.4, plus the module-based, 72MHz /2.4GHz 12X MV. In fact, the module-based 12X MV’s 2.4GHz performance and minimal- latency response speed will be absolutely identical to those of the integrated 12X 2.4’s.
Exclusive ModelMatch™ technology to prevent “wrong model syndrome,” plus a 50-model memory.Here’s how ModelMatch works: If you’re operating on 2.4GHz and your transmitter doesn’t “recognize” your model as the selected model, when your airborne system is turned on, there’ll be absolutely no control response. You’ll be alerted that something’s wrong and a costly crash may be averted.* Also, the 12X’s included PC Data Transfer System permits you to upload an unlimited number of model setups from your transmitter to your computer, then access and download any 50 of them to your 12X transmitter’s model memory for use at the field.
Unmatched JR quality in every detail.From its exclusive, durable, precision-cast magnesium transmitter housing to its ultra-legible, high-resolution backlit display, everything about the 12X speaks of the kind of quality that’s a benchmark of JR equipment. The ultra-smooth, quad-bearing stick assemblies, proven rolling selector data input, accessible shoulder mounted momentary contact switches––and details like the custom-naming capability for flight modes––all contribute to the unmistakable feeling that you’re flying with the very best, most intelligently conceived pro-class equipment that’s ever been introduced.
12X Features Include:
  • DSM/DSM2 Compatibility
  • Compatibility with all Spektrum and JR DSM Brand Aircraft Receivers
  • R1221 12 channel receiver (with JRP1200 dedicated 2.4 tx only)
  • 50 Model Memory
  • Advanced programming with more features for today's complex models
  • Programming for Air, Heli, and Sailplane models
  • Improved gimbal assemblies for better performance and feel
发表于 2008-1-22 14:17 | 只看该作者
這不知道要多少錢???
真想趕快升級...9xII已經拿膩了...
发表于 2008-1-22 14:28 | 只看该作者
差不多就可以了,不用追求高端货,没底的。
发表于 2008-1-22 14:38 | 只看该作者
直升机7通道就够了,多的那5通道拿来干啥?
发表于 2008-1-22 16:19 | 只看该作者
不好看!!
发表于 2008-1-25 09:50 | 只看该作者
原帖由 uery 于 2008-1-22 14:38 发表
6通就够了啊,7通多出一个做什么用的?
