查看: 1890|回复: 6
别说我火星 这才是最强的小小大脚车! 星星的TLT-1小大脚!
发表于 2003-12-17 20:35 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
RockBuster
以前只有日文版的网页, 看不懂.
现在英文版的出来了, 瞧了一下, 被吸引了.
The first release in Tamiya’s new 1/18 Scale Little Gear Series, the TLT-1 (Tamiya Little Truck) Rock Buster harnesses the motor power of a 1/10th scale vehicle in a mini-sized 1/18th scale truck. Designed to use standard size electronics such as a 540 size motor, most electronic
使用标准540大小的马达! (大家目前拥有的大堆540多少多少T马达可以派上用场了!)
可以使用普通大小的电变!
speed controls, standard size receiver and servo/s makes
使用标准大小的接收机和Servo!!!
the TLT-1 one of the most versatile 1/18th scale vehicles in the market. Featuring 4WD, superior four link cantilever
四轮驱动!!
四轮转向兼容!!! (估计需少量改造)
suspension and four wheel steering capabilities, the TLT-1 also performs as well as its 1/10th scale counterparts. Being less than 30cm long, this truck can be as much fun in the house as it is outside. A lightweight durable
//可以在家里玩!
polycarbonate body combined with loads of metal parts makes this little truck super tough. Box comes with handle and can be used as a simple carry case even after assembly.
附送盒子, 车子安装好之后, 也可以放进盒子里面, 也方便携带.
Tamiya will also be releasing a specially designed triangular battery pack to fit the TLT-1 battery holder.
About the model
Powered by a 540 size motor (not included)
Specially designed wheels and tires
Lightweight aluminum chassis
4-wheel drive with belt drive transmission
四轮驱动
皮带驱动
4-wheel steering capabilities (2 servos required)
四轮转向, 双陀机需要,
Four link, push rod cantilever suspension with four aluminum dampers
Overall length approximately 280mm
全长280毫米
Requires Tamiya TLT-1 Battery Pack and an electronic speed control
专用电池盒! (是不是需要另外购买呢? 唉)
http://www.tamiyausa.com/product/item.php?product-id=47201
点击查看详情
发表于 2003-12-17 21:40 | 只看该作者
底盘够高的阿。
发表于 2007-11-25 11:31 | 只看该作者
不错,我喜欢
发表于 2007-11-26 01:50 | 只看该作者
浓缩的才是精华!:em26:
发表于 2007-11-26 14:45 | 只看该作者
喜欢```````
发表于 2007-11-26 20:23 | 只看该作者
田宫的:em24:
发表于 2007-11-28 22:02 | 只看该作者
哈哈 。。。偶有一个哦 。。。
不过早已改正了爬爬 。。。变大了 。。。很皮实耐用哦  。。。
