查看: 3650|回复: 14
APM,MWC,等,各种机架电机权重分析。
发表于 2012-5-29 14:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
丛别的网站上转过来的,做个备份。
Ardu Pirate's Motor Mixing Guidelines
Hi Pirates, based on Hein's comments, I'm going to try to explain how is the mixing of the motors done, depending on the layout/position of your ship's motors.
All mixing depends directly on the motor's positions and layout proportions. Depending on it's position each motor needs to apply different strength to pitch and roll axles. In other words, the farthest a motor is from a axle, the stronger it will have to pull.
This strength is set for each motor in the motor mixing (motors.pde) as meanings of a percentual value, that will multiply pitch and roll values used to calculate the final value for each motor.
When the percentage is 100%, it is not necessary to add any value, as we would be multiplying by 1.
Pitch and Roll Axles
Pitch and Roll axles will be used as reference to find the needed strength for each motor:
The axles layout will help to understand and locate what will the values for each motor be, and it's sign.
As for the Yaw, things are simpler, as it just depends on the rotation direction of the motor:
If Motor turns ClockWise (CW) Yaw is Negative.
If Motor turns CounterClockWise (CCW) Yaw is Positive.
I will try to explain it using exampes for the frames we commonly use:
Quad + mode
Ok, let's start with a simple Quad in + mode:
As all 4 motors are on the axles, they all will have 100% and 0% as strength values, in more detail:
Motor         Pitch         Roll         Yaw
0 Right CCW         -0%         -100%         +
1 Left CCW         +0%         +100%         +
2 Front CW        +100%         0%         -
3 Back CW        -100%         0%         -
Thus the resulting pseudo-code would have these signs and values:
rightCCW = - (0 * Pitch) - (1 * Roll) + Yaw
leftCCW = + (0 * Pitch) + (1 * Roll) + Yaw
frontCW = + (1 * Pitch) + (0 * Roll) - Yaw
backCW = - (1 * Pitch) - (0 * Roll) - Yaw
and the final code in Motors.pde, adding throttle and controlling total motor value not to get out of bounds, would be:
rightCCW = constrain(throttle - control_roll + control_yaw, minThrottle, 2000);
leftCCW = constrain(throttle + control_roll + control_yaw, minThrottle, 2000);
frontCW = constrain(throttle + control_pitch - control_yaw, minThrottle, 2000);
backCW = constrain(throttle - control_pitch - control_yaw, minThrottle, 2000);
Quad X mode
Next, Quad in X mode:
This tiem all 4 motor are rotated 45 from the axles, they all will have 71% as strength values in pitch and roll, in more detail:
0 FrontRight CCW         +71%         -71%         +
1 BackLeft CCW         -71%         +71%         +
2 FrontLeft CW         +71%         +71%         -
3 BackRight CW         -71%         -71%         -
Thus the resulting pseudo-code should have these signs and values:
FrontRightCCW = +(0.71 * Pitch) - (0.71 * Roll) + Yaw
BackLeftCCW = -(0.71 * Pitch) + (0.71 * Roll) + Yaw
FrontLeftCW = +(0.71 * Pitch) + (0.71 * Roll) - Yaw
BackRightCW = -(0.71 * Pitch) - (0.71 * Roll) - Yaw
BUT, as we would be lowering the overall power to 71%, and all values are the same we can simply uses 100% for all values, this way we're still keeping the same proportion of strength between motors, so there will be no difference in stability, but we will be getting all the available power.
FrontRightCCW = constrain(throttle + control_pitch - control_roll + control_yaw, minThrottle, 2000);
BackLeftCCW = constrain(throttle - control_pitch + control_roll + control_yaw, minThrottle, 2000);
FrontLeftCW = constrain(throttle + control_pitch + control_roll - control_yaw, minThrottle, 2000);
BackRightCW = constrain(throttle - control_pitch - control_roll - control_yaw, minThrottle, 2000);
Hexa classic mode
Next, HEXA in classic mode, with all motors at the same distance from center frame:
More in detail:
7 Front CW         +100%         +0%         +
2 FrontLeft CCW         +50%         +87%         -
1 BackLeft CW         -50%         +87%         +
4 FrontRight CCW         +50%         -87%         -
3 BackRight CW         -50%         -87%         +
8 Back CCW         -100%         -0%         -
FrontCW = + ( 1 * Pitch) + ( 0 * Roll) - Yaw
FrontLeftCCW = + (0.5 * Pitch) + (0.87 * Roll) + Yaw
BackLeftCW = - (0.5 * Pitch) + (0.87 * Roll) - Yaw
FrontRightCCW = + (0.5 * Pitch) - (0.87 * Roll) + Yaw
BackRightCW = - (0.5 * Pitch) - (0.87 * Roll) - Yaw
BackCCW = - ( 1 * Pitch) - ( 0 * Roll) + Yaw
So all 4 left and righ motors will have a pitch strength of 50% and roll of 87% while front and back will only have 100% on pitch and no effect on roll.
FrontCW = constrain(throttle + control_pitch - control_yaw, minThrottle, 2000);
FrontLeftCCW = constrain(throttle + (0.5 * control_pitch) + (0.87 * control_roll) + control_yaw, minThrottle, 2000);
BackLeftCW = constrain(throttle - (0.5 * control_pitch) + (0.87 * control_roll) - control_yaw, minThrottle, 2000);
FrontRightCCW = constrain(throttle + (0.5 * control_pitch) - (0.87 * control_roll) + control_yaw, minThrottle, 2000);
BackRightCW = constrain(throttle - (0.5 * control_pitch) - (0.87 * control_roll) - control_yaw, minThrottle, 2000);
BackCCW = constrain(throttle - control_pitch + control_yaw, minThrottle, 2000);
NOTE: The current NG code, is not using the 87% on roll, but 100%; in this case it is like the all four left and right motors were a bit farther away from center (13%).
Hexa H mode
Next, HEXA in H mode, with three motors on each side in a "H" shape, forming a perfect square:
More in detail:
1 FrontLeft CW         +100%         +100%         -
6 Left CCW         +0%         +100%         +
5 BackLeft CW         -100%         +100%         -
2 FrontRight CCW         +100%         -100%         +
3 Right CW         -0%         -100%         -
4 BackRight CCW         -100%         -100%         +
FrontLeftCW = + (1 * Pitch) + (1 * Roll) - Yaw
LeftCCW = + (0 * Pitch) + (1 * Roll) + Yaw
BackLeftCW = - (1 * Pitch) + (1 * Roll) - Yaw
FrontRightCCW = + (1 * Pitch) - (1 * Roll) + Yaw
BackRightCW = - (0 * Pitch) - (1 * Roll) - Yaw
BackCCW = - (1 * Pitch) - (1 * Roll) + Yaw
So in this case as all values are 100%, no value is needed, only signs.
FrontCW = constrain(throttle + control_pitch + control_roll - control_yaw, minThrottle, 2000);
FrontLeftCCW = constrain(throttle + control_pitch + control_roll + control_yaw, minThrottle, 2000);
BackLeftCW = constrain(throttle - control_pitch + control_roll - control_yaw, minThrottle, 2000);
BackCCW = constrain(throttle - control_pitch - control_roll + control_yaw, minThrottle, 2000);
NOTE: If the sides where to be closer to each other, a roll value would have to be added, as they would have to have less strength than pitch; and viceversa, if you got your front and back motors closer, you would have to add a pitch value.
 楼主| 发表于 2012-5-29 14:18 | 只看该作者
Octo classic mode
Next, Octo in classic mode, with one motor at front and back:
More in detail:
0 Front CW         +100%         +0%         -
1 FrontRight CCW         +71%         -71%         +
2 Right CW         +0%         -100%         -
3 BackRight CCW         -71%         -71%         +
6 Back CW         -0%         -0%         -
7 BackLeft CCW         -71%         +71%         +
9 Left CW         +0%         +100%         -
10 FrontLeft CCW         +71%         +71%         +
FrontCW = + (1 * Pitch) + (0 * Roll) - Yaw
FrontRightCCW = + (0.71 * Pitch) - (0.71 * Roll) + Yaw
RightCW = + (0 * Pitch) - (1 * Roll) - Yaw
BackRightCCW = - (0.71 * Pitch) - (0.71 * Roll) + Yaw
BackCW = - (0 * Pitch) - (0 * Roll) - Yaw
BackLeftCCW = - (0.71 * Pitch) + (0.71 * Roll) + Yaw
LeftCW = + (0 * Pitch) + (1 * Roll) - Yaw
FrontLeftCCW = + (0.71 * Pitch) + (0.71 * Roll) + Yaw
FrontRightCCW = constrain(throttle + (0.71 * control_pitch) - (0.71 * control_roll) + control_yaw, minThrottle, 2000);
RightCW = constrain(throttle - control_roll - control_yaw, minThrottle, 2000);
BackRightCCW = constrain(throttle - (0.71 * control_pitch) - (0.71 * control_roll) + control_yaw, minThrottle, 2000);
BackCW = constrain(throttle - control_pitch - control_yaw, minThrottle, 2000);
BackLeftCCW = constrain(throttle - (0.71 * control_pitch) + (0.71 * control_roll) + control_yaw, minThrottle, 2000);
LeftCW = constrain(throttle + control_roll - control_yaw, minThrottle, 2000);
FrontLeftCCW = constrain(throttle + (0.71 * control_pitch) + (0.71 * control_roll) + control_yaw, minThrottle, 2000);
Octo X mode
Next, Octo in "Quad" mode, 2 motors at the front, 2 at the back, 2 left and 2 right:
More in detail:
0 Front CW         +92%         -38%         -
1 Front CCW         +92%         +38%         +
2 Left CW         +38%         +92%         -
3 Left CCW         -38%         +92%         +
6 Right CW         -38%         -92%         -
7 Right CCW         +38%         -92%         +
9 Back CW         -92%         +38%         -
10 Back CCW         -92%         -38%         +
To be able to have full power, I'll increase values to 100%, so proportionally they will be: 92% = 100% and 38% = 42%, thus giving these values:
FrontCW = + (1 * Pitch) - (0.42 * Roll) - Yaw
FrontCCW = + (1 * Pitch) + (0.42 * Roll) + Yaw
LeftCW = + (0.42 * Pitch) + (1 * Roll) - Yaw
LeftCCW = - (0.42 * Pitch) + (1 * Roll) + Yaw
RightCW = - (0.42 * Pitch) - (1 * Roll) - Yaw
RightCCW = + (0.42 * Pitch) - (1 * Roll) + Yaw
BackCW = - (1 * Pitch) + (0.42 * Roll) - Yaw
BackCCW = - (1 * Pitch) - (0.42 * Roll) + Yaw
FrontCW = constrain(throttle + control_pitch - (0.42 * control_roll) - control_yaw, minThrottle, 2000); // Front Motor CW
FrontCCW = constrain(throttle + control_pitch + (0.42 * control_roll) + control_yaw, minThrottle, 2000); // Front Motor CCW
LeftCW = constrain(throttle + (0.42 * control_pitch) + control_roll - control_yaw, minThrottle, 2000); // Left Motor CW
LeftCCW = constrain(throttle - (0.42 * control_pitch) + control_roll + control_yaw, minThrottle, 2000); // Left Motor CCW
RightCW = constrain(throttle - (0.42 * control_pitch) - control_roll - control_yaw, minThrottle, 2000); // Right Motor CW
RightCCW = constrain(throttle + (0.42 * control_pitch) - control_roll + control_yaw, minThrottle, 2000); // Right Motor CCW
BackCW = constrain(throttle - control_pitch + (0.42 * control_roll) - control_yaw, minThrottle, 2000); // Back Motor CW
BackCCW = constrain(throttle - control_pitch - (0.42 * control_roll) + control_yaw, minThrottle, 2000); // Back Motor CCW
Files to Check when adding new motor mixing
COMMS.pde (Show_Platform_Info())
Motors.pde (motor_output())
system.pde (APM_Init())
Well Pirates, that's about it, I hope I've been able to enlighten a bit more your pirte minds! Now you can go and design your own weird shape!!
I hope you got the idea!
any comments / addings / corrections are welcome!!
Happy Landings,
Dani
发表于 2012-5-29 15:10 | 只看该作者
:em22: :em17:
发表于 2012-5-29 15:30 | 只看该作者
好东东,就是不懂:em17:
发表于 2012-5-29 18:13 | 只看该作者
哦,这就是那段玉兔被指责抄袭MWC的代码的地方了。不同的飞控,在把俯仰控制转换为各个电机输出动力时用的算法是不一样的。恰巧玉兔的代码和MWC的是一样的。
发表于 2012-5-30 21:15 | 只看该作者
天书~~:em22:
发表于 2012-5-30 22:22 | 只看该作者
:em26:
发表于 2012-5-30 23:17 | 只看该作者
看不懂
发表于 2012-5-31 07:26 | 只看该作者
我觉得其实这段代码对其他的飞控也是差不多的,大家都一样的结构。
 楼主| 发表于 2012-5-31 09:06 | 只看该作者
完全一样就有点说不过去了。我两次写的东西还不完全一样呢。
发表于 2012-6-1 11:45 | 只看该作者
天书:em23:
发表于 2012-7-19 15:36 | 只看该作者
这种等轴距的好理解
V型 H机架等
异形机架应该怎么计算呢
APM2里面 4轴 6轴 8轴 就直接 按电机角度然后解算COS和SIN值
可是我现在搞不明白 V6型异形机架或其他非等轴距机架怎么计算
发表于 2012-7-19 17:41 | 只看该作者
看不懂。。。。
出手机了~http://bbs.5imx.com/bbs/viewthread.php?tid=653482&extra=page%3D1
发表于 2012-7-19 21:06 | 只看该作者
确实是天书。
