2款,6通和9通,都可以加装卫星天线加强,扩大接收距离至1公里以上
非漫天飞的假货spektrum 6100E可比拟,价格也非常好至少比JR原厂便宜一倍
Compatible with all Spektrum DSM2 Air transmitters.
The new range of OrangeRx receivers are built using original components and MCUs and with state of the art SMT automation to ensure a quality product each and every time.
All OrangeRx receivers are QC tested before leaving the factory.
The OrangeRx will work with ANY Aircraft Spektrum DSM2 2.4Ghz transmitter
The OrangeRx 6ch is only 3.7g in weight and 19.5x30x10mm in size. Great for small planes, helis, parkflyers or even medium sized sport planes.
Key features.
Super light weight 3.7g / 9.8 grams with case.
Compatible with DSM2 1024/2048 aircraft radio and module systems.
6 Channels.
Compact design 19.5mm x 30mm x 10mm, with case 43x22x13mm.
Short 29mm antennas for mounting in almost any location.
Input voltage: 3.7~9.6V.
Satellite port included.
Two CYP chips used. Making it a true outdoor receiver system.
Warranty.
12 Month replacement guarantee!
Included.
OrangeRx-6 DSM2 Compatible receiver |
