1622
Log File C:/Program Files/Mission Planner/logs/QUADROTOR/1/2015-01-18 11-50-17.log
Size (kb) 1621.5419921875
No of lines 22335
Duration 1:40:27
Vehicletype ArduCopter
Firmware Version V3.2
Firmware Hash c8e0f3e1
Hardware Type
Free Mem 0
Skipped Lines 0
Test: Autotune = UNKNOWN - No ATUN log data
Test: Balance/Twist = GOOD -
Test: Brownout = FAIL - Truncated Log? Ends while armed at altitude 12.75m
Test: Compass = GOOD - No MAG data, unable to test mag_field interference
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = FAIL - ERR found: FLT_MODE
Test: GPS = FAIL - Min satellites: 7, Max HDop: 203.46
Test: Parameters = GOOD -
Test: PM = GOOD -
Test: Pitch/Roll = FAIL - Roll (-84.09, line 22163) > maximum lean angle (45.00)
Test: Thrust = GOOD -
Test: VCC = FAIL - VCC below minimum of 4.6v (4.382v)
