查看: 888|回复: 2
求hcp100模型文件。
发表于 2015-2-16 16:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
哪位大神可以分享给我,小弟感激不尽。
 楼主| 发表于 2015-2-16 16:51 | 只看该作者
内置2401高频头,现在没有模型文件,求大神分享。
发表于 2015-2-23 03:15 | 只看该作者
name=fbl100
mixermode=Standard
[radio]
protocol=HiSky
num_channels=6
fixed_id=111111
tx_power=30mW
[channel1]
template=cyclic1
[channel2]
template=cyclic2
[channel3]
safetysw=!HOLD0
safetyval=-110
failsafe=-125
template=complex
[mixer]
src=THR
dest=Ch3
curvetype=9point
points=-100,-39,3,29,55,70,84,94,100
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=9point
points=100,98,95,93,90,92,95,97,100
[channel4]
template=expo_dr
[mixer]
src=RUD
dest=Ch4
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=SW A1
scalar=75
curvetype=expo
points=0,0
[mixer]
src=RUD
dest=Ch4
switch=SW A2
scalar=50
curvetype=expo
points=0,0
[channel6]
template=cyclic3
[channel7]
template=expo_dr
[mixer]
src=FMODE0
dest=Ch7
scalar=40
curvetype=fixed
[mixer]
src=FMODE0
dest=Ch7
switch=FMODE1
scalar=0
curvetype=fixed
[virtchan1]
template=expo_dr
[mixer]
src=AIL
dest=Virt1
curvetype=expo
points=35,35
[mixer]
src=AIL
dest=Virt1
switch=SW A1
scalar=65
curvetype=expo
points=15,15
[mixer]
src=AIL
dest=Virt1
switch=SW A2
scalar=40
curvetype=expo
points=4,4
[virtchan2]
template=expo_dr
[mixer]
src=ELE
dest=Virt2
curvetype=expo
points=35,35
[mixer]
src=ELE
dest=Virt2
switch=SW A1
scalar=65
curvetype=expo
points=15,15
[mixer]
src=ELE
dest=Virt2
switch=SW A2
scalar=40
curvetype=expo
points=4,4
[virtchan3]
template=complex
[mixer]
src=THR
dest=Virt3
curvetype=9point
points=-20,-9,3,15,27,45,63,81,100
[mixer]
src=THR
dest=Virt3
switch=FMODE1
curvetype=9point
points=-100,-75,-50,-25,0,25,50,75,100
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[swash]
type=120X
ail_inv=1
ail_mix=20
ele_mix=20
col_mix=36
[timer1]
type=countdown
src=Ch3
time=180
[timer2]
src=Ch3
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,None
Toggle=13,10,0,5,0,None
Toggle=22,10,0,4,0,None
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
