查看: 11167|回复: 81
音频线+ppjoy可以玩G3
发表于 2006-4-23 20:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
跟用音频线玩G2差不多。
唯一不同的是G3需要用软件仿真狗(emu.exe)来启动,避开对序列号的检查。
我是用电驴下的。另外我猜测,G3的注册码要和软件狗对应起来,也就是说只能用同一个序列号安装。
还有,我下的G3共两张cd,第二张里的升级软件一定要安装才行。
正在爽玩中:em15:
下面是英文的说明:
Instructions:
- Install the game.
- Install the helicopters update, found on CD2 - RealFlight3_00_366HeliUpdate.exe
- Run the launcher and use our serial numbers -> 00513084-G3-1060111268 and 3987906-I2-016913
- Copy the emu.exe Emulator from crack dir on CD2 to the installation program directory typically
  at X:\Program Files\RealFlightG3
- Make sure you have at least one joystick configured and connected.
  If you are using the older G2 joystick go to Control Panel/Game Controllers/Add
  Select Custom and select a 4 Axis Joystick, in Controller Name type: G3 and click
  OK to add the joystick.
  Make sure that in the Joystick list it shows OK.
  If you have other joystick and not the older G2 one, just make sure it appears on the
  joystick list otherwise add it.
- Run the Emu.exe Emulator from the program directory and press "Launch G3"xx
- After the simulator was loaded, from the simulator menu select Controller/Select Controller
  and select the "Interlink Joystick (G2)"
- Select Controller/Controller Calibration in order to calibrate your joystick.
- After calibration is done, you can press "2" and see the joystick controls appear on the
  screen. This will help you see if the joystick is configured ok.
- Enjoy !! ;)
Known issues and special configuration:
- Emulator
If you get "Unknown Realflight version !!!" , you are not using the right ISO distribution, please
make sure you have the right one :/
- Loading Errors:
Sometimes when the game tries to load it throws ugly errors saying "Error creating effect xxxx"
or something similar and halts, it can be right on the start or after 180 elements or so ...
This is caused by your Video Card Adapter that is not 100% compatible with DirectX 9.0c.
Check out: http://12.156.2.54/forums/showthread.php?t=9243 or seek google for this error.
You will need a quite newish card in order to run this simulator.
If you still want to to overcome this problem you can try and select the
"Try to overcome loading problems" checkbox in the Emulator this may actually work in some
cases but not guaranteed.
Sometimes using this flag can just hang the game when it is trying to load :/
- Joystick Configuration:
By default this game is built for a 4 Axis joystick.
You can use an older Joystick version from the G2 game and it will run smoothly.
If some Axis of the joystick are opposite you can use the Controller/Channel Mapping option
in the game to remap the controls to fit your joystick.
One problem exists though is that the older joystick does not have a channel for Flaps so
Flaps will be disabled using the older G2 control.
However, if you would like and try connecting other joysticks or even build one of your
own I recommend using PPJoy and PPJoyJoy (do some google on it):
http://www.dikant.de/index.php?o ... ry&filecatid=15
http://www.simtel.net/product.download.mirrors.php?id=75176
These 2 programs let you map an existing joystick or keyboard to another joystick.
You can try and play with these in combination with the emulator.
If you are having problems using your joystick and the emulator, you can try and configure the
emulator to map into your joystick channels.
In order to do that, run the Simulator from the Emulator and then press "2" in the Simulator,
this will show the joystick controls on the screen.
Now select the "X1 Axis" in the Emulator and select a number from 1 - 60 and go back to the
simulator and try to move the X1 Axis of your joystick in order to see if it affects the control
in the game or not.
If it does affect so you have probably found the right value for this Axis, if not you should
select another number and repeat the test and so on ....
Repeat this procedure for the all of the Axis list in the Emulator and done.
Make sure that after finding all the Axis mappings, you need to select the Controller Calibration
from the menu and calibrate the joystick otherwise it won't be configured and calibrated right.
 楼主| 发表于 2006-4-23 20:43 | 只看该作者
补充一下,根据英文的说明,如果有其它的模拟器,也可以玩G3了。只需先启动仿真狗绕开G3的序列号检查就可以了。
发表于 2006-4-24 08:52 | 只看该作者
请问楼主,emu.exe哪里下载?能给个链接吗?
谢谢!
 楼主| 发表于 2006-4-24 10:41 | 只看该作者
用电驴可以下。搜索“G3 dongle emu”,“G3 emu”等关键词可以找到。
还可以用电驴下载realflight g3,CD2里面有emu和升级。
或者给我邮箱,我发一份给你。
升级后,才能输入序列号,我用的是:00513084-G3-1060111268 and 3987906-I2-016913
[ 本帖最后由 小刀 于 2006-4-24 10:50 编辑 ]
发表于 2006-4-24 12:40 | 只看该作者
感谢,搜索下载去
发表于 2006-4-24 18:15 | 只看该作者
搜索出好多个不知道那个是啊!能不能把你下载的G3文件的 ed2k链接 提供一下啊?
可以察看共享文件的ed2k链接,并且复制。
步骤:鼠标右健点击共享文件 → 察看ed2k链接
→ 复制内容
发表于 2006-4-24 19:37 | 只看该作者
还是E-mail给我吧,谢谢!
h10zg11@yeah.net
 楼主| 发表于 2006-4-24 21:51 | 只看该作者
原帖由 webug 于 2006-4-24 18:15 发表
→ 复制内容
RealFlight.G3.Dongle.Emulator-lz0 also for ver 3.0.0.410.rar (197.25 KB)
发表于 2006-4-25 20:45 | 只看该作者
好啊!麻烦楼主也给我个软件仿真狗(emu.exe)吧!我的邮箱地址yun733@163.com  谢谢!
发表于 2006-4-25 20:51 | 只看该作者
太好了,麻烦楼主也给我个软件仿真狗(emu.exe)吧!我的邮箱地址liu5362@tom.com,谢谢了
 楼主| 发表于 2006-4-25 21:16 | 只看该作者
已发。
用成功了的兄弟们过来顶顶哈
发表于 2006-4-26 09:07 | 只看该作者
G3可以用了,谢谢楼主!!!:em00:
发表于 2006-4-26 09:50 | 只看该作者
给我一份行吗?谢谢!!
liuxusheng2005@yahoo.com.cn
发表于 2006-4-26 10:16 | 只看该作者
用于G3的随便哪个版本都可以吗?
另外有没有能够把原装并口G2狗用于PPJOY软件或者当作游戏手柄的软件?用音频线总跳舵阿,用串口线还得现做,能不能废物利用阿
发表于 2006-4-26 10:24 | 只看该作者
如此的好东东一定要顶!
楼主,也发一份emu.exe给我吧,谢谢了!
lc499@tom.com
 楼主| 发表于 2006-4-26 12:32 | 只看该作者
原帖由 webug 于 2006-4-26 10:16 发表
用于G3的随便哪个版本都可以吗?
版本估计有要求题,需要你去试试了:em15:。
根据英文说明,可以作遥控器映射的,原来的英文说明也是说可以用G2的狗狗滴。
 楼主| 发表于 2006-4-26 12:33 | 只看该作者
emu软件都给各位需要的兄弟们发了。祝各位飞得爽。
发表于 2006-4-26 13:30 | 只看该作者
刀老弟,按你教的方法,装了EMU,我的G3运行起来后老是提示"没发现授权的接口设备"这问题怎么解决?
 楼主| 发表于 2006-4-26 13:48 | 只看该作者
原帖由 Hyun 于 2006-4-26 13:30 发表
很可能是g3版本,序列号等不一致。
我说说我的安装过程:
1:电驴下了G3的cd1,和cd2共两张碟子;
2:cd2里就带了升级程序(需要安装,100多兆),emu程序和序列号;
3:正常安装时提示快捷方式安装不成功,此时安装cd2里的升级软件,安完后选择输入自带的序列号;
4:用emu程序启动G3。此时我还没安装ppjoy,但可以进入到G3程序里了。
5:安装ppjoy,JRpcm(smartpropo里提取的),配置后,接上音频线,就可以游戏了。
:em15:
发表于 2006-4-26 16:07 | 只看该作者
收到,正在安装,谢谢.
