查看: 1217|回复: 3
skylark tiny osd 3的gps能给apm用么?
发表于 2016-1-10 16:39 ——“来自手机” | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
闲置几年了,翻出来电池都有点锈。最近调apm,老是不能定位,想换这个上去试试,不知道是否支持?手头没有线
 楼主| 发表于 2016-1-10 18:47 ——“来自手机” | 只看该作者
找到根线接电脑看了9600波特率1hz,应该可以用!
 楼主| 发表于 2016-1-10 19:23 ——“来自手机” | 只看该作者
我的apm用gps设置,一直不能定位,莫非设置错误?
 楼主| 发表于 2016-1-11 20:33 | 只看该作者
skylarktinyosd所用gps参数:
MON-VER - 0A 04 28 00 36 2E 30 32 20 28 33 36 30 32 33 29 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 30 30 30 34 30 30 30 37 00 00
CFG-ANT - 06 13 04 00 1B 00 8B A9
CFG-DAT - 06 06 02 00 00 00
CFG-FXN - 06 0E 24 00 0C 00 00 00 00 00 00 00 00 00 00 00 10 27 00 00 10 27 00 00 D0 07 00 00 18 FC FF FF 00 00 00 00 00 00 00 00
CFG-INF - 06 02 0A 00 00 00 00 00 00 00 00 00 00 00
CFG-INF - 06 02 0A 00 01 00 00 00 87 87 87 87 87 87
CFG-INF - 06 02 0A 00 03 00 00 00 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0B 30 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0B 32 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0B 31 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0B 01 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 0B 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 09 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 02 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 06 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 07 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 21 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0A 08 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 22 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 04 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 01 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 02 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 32 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 06 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 03 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 30 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 20 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 21 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 11 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 01 12 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 02 20 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0D 03 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 0D 01 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 00 01 01 01 01 01 01
CFG-MSG - 06 01 08 00 F0 01 01 01 01 01 01 01
CFG-MSG - 06 01 08 00 F0 02 01 01 01 01 01 01
CFG-MSG - 06 01 08 00 F0 03 01 01 01 01 01 01
CFG-MSG - 06 01 08 00 F0 04 01 01 01 01 01 01
CFG-MSG - 06 01 08 00 F0 05 01 01 01 01 01 01
CFG-MSG - 06 01 08 00 F0 06 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 07 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 08 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 09 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F0 0A 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F1 00 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F1 03 00 00 00 00 00 00
CFG-MSG - 06 01 08 00 F1 04 00 00 00 00 00 00
CFG-NAV5 - 06 24 24 00 FF FF 00 03 00 00 00 00 10 27 00 00 05 00 FA 00 FA 00 64 00 2C 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CFG-NAVX5 - 06 23 28 00 00 00 FF 1F FF FF FF FF 03 02 03 10 0A 00 00 01 00 00 F8 05 00 00 00 00 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
CFG-NMEA - 06 17 04 00 00 23 00 02
CFG-PM - 06 32 18 00 00 06 00 00 04 90 00 00 E8 03 00 00 10 27 00 00 00 00 00 00 02 00 00 00
CFG-PRT - 06 00 14 00 00 0F 42 00 84 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00
CFG-PRT - 06 00 14 00 01 0F 42 00 C0 08 00 00 80 25 00 00 03 00 03 00 00 00 00 00
CFG-PRT - 06 00 14 00 02 0F 42 00 C0 08 00 00 80 25 00 00 00 00 00 00 00 00 00 00
CFG-PRT - 06 00 14 00 03 0F 42 00 00 00 00 00 00 00 00 00 03 00 03 00 00 00 00 00
CFG-PRT - 06 00 14 00 04 0F 42 00 00 32 00 00 00 00 00 00 03 00 03 00 00 00 00 00
CFG-RATE - 06 08 06 00 E8 03 01 00 01 00
CFG-RINV - 06 34 18 00 00 4E 6F 74 69 63 65 3A 20 6E 6F 20 64 61 74 61 20 73 61 76 65 64 21 00
CFG-RXM - 06 11 02 00 00 00
CFG-SBAS - 06 16 08 00 01 03 03 00 D5 CA 06 00
CFG-TP - 06 07 14 00 40 42 0F 00 A0 86 01 00 01 01 00 00 32 00 00 00 00 00 00 00
CFG-TP5 - 06 31 20 00 00 00 00 00 32 00 00 00 40 42 0F 00 40 42 0F 00 00 00 00 00 A0 86 01 00 00 00 00 00 F7 00 00 00
CFG-TP5 - 06 31 20 00 01 00 00 00 32 00 00 00 04 00 00 00 01 00 00 00 48 E8 01 00 A0 86 01 00 00 00 00 00 FE 00 00 00
CFG-USB - 06 1B 6C 00 46 15 A6 01 00 00 00 00 64 00 00 01 75 2D 62 6C 6F 78 20 41 47 20 2D 20 77 77 77 2E 75 2D 62 6C 6F 78 2E 63 6F 6D 00 00 00 00 00 00 75 2D 62 6C 6F 78 20 36 20 20 2D 20 20 47 50 53 20 52 65 63 65 69 76 65 72 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
