查看: 2957|回复: 19
RX122 V2准备入手RMB3000+
发表于 2016-4-28 09:37 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
 楼主| 发表于 2016-4-28 09:45 | 只看该作者
Atom Racer Frame/canopy:
RotorX RX122 Atom V2 3K Carbon Fibre frame
Custom molded canopy made out of crash resistant polycarbonate, with interlocking camera mounts
Electronics :
RX122 Atom Racer custom stacked electronics
STM32 F3 Flight controller running Betaflight/Cleanflight  (Fastest F3 Flight Controller available) - Pre-tuned for the Atom
OSD (On Screen Display) displays Battery Voltage, Amps and Timer among other features that allow you to configure you new racing drone.
600TVL CMOS FPV Camera, 120 deg Field of View for optimal view angle
Regulated and filtered power for Cam and VTx (5V/12V/VBatt switchable)
Buzzer for finding lost models and indicating battery status
Addressable LED’s visually display Atom Racer status
TBS Unify Pro VTX(25-800mw) with selectable Band Channel and Output power
Custom made Silabs F396 ESCs (Electronic speed controllers) Oneshot BlHeli preflashed and calibrated
Current Sensor, PDB, and connectors for add-on modules
Motors/Propellers
Custom made RotorX RX1105 Brushless motors and RotorX proprietary quiet and powerful propellers (RX2535)
Custom RotorX RX1306 Brushless motors (Pro Upgrade) proprietary ultra strong and powerful propellers (RX3040T)
Controller/Transmitter
Built for multirotors
Goggle port for power & video
Easy channel scanning capability to find your video feed
40ch 5.8ghz receiver with FPV screen
Built-in 6400mah lithium Ion Battery
Built-in Long Range FPV circular polarized antenna
JR Module port for maximum compatibility with all protocols
USB Chargeable
发表于 2016-4-28 10:01 | 只看该作者
那个控是重复投资的鸡肋
 楼主| 发表于 2016-4-28 10:12 | 只看该作者
prowerboy 发表于 2016-4-28 10:01
那个控是重复投资的鸡肋
好看 携带方便 距离远 可以控制2KM
发表于 2016-4-28 10:51 | 只看该作者
配件方便购买不·?
发表于 2016-4-28 10:54 | 只看该作者
不喜欢成品机
发表于 2016-4-28 11:07 | 只看该作者
我比較喜歡rx155 ...
发表于 2016-4-28 11:10 | 只看该作者
其實這都是一般自組機 , 只是加上自家公司的圖傳接收一體控 , 可以單買機架自組的 ...
 楼主| 发表于 2016-4-28 11:24 | 只看该作者
amlzeus 发表于 2016-4-28 11:07
我比較喜歡rx155 ...
RX155我早就有了 只是被我包裹成木乃伊了
发表于 2016-4-28 11:53 | 只看该作者
发表于 2016-4-28 13:21 | 只看该作者
发表于 2016-4-28 13:22 | 只看该作者
发表于 2016-4-28 17:45 | 只看该作者
喜欢这浆 设计不错,不知道什么时候能买到!
 楼主| 发表于 2016-4-28 19:31 | 只看该作者
rotorx官网上有卖 但是在1104上效果不好 等飞越出mt1106再上这种桨
发表于 2016-4-28 21:19 | 只看该作者
效果不好, kv值太高了吗?
 楼主| 发表于 2016-4-29 07:56 | 只看该作者
qq767379238 发表于 2016-4-28 21:19
效果不好, kv值太高了吗?
1104本身拉力不足  上4叶 效率会更低
发表于 2016-4-29 08:09 | 只看该作者
感觉不抗风,轻轻一吹就走
 楼主| 发表于 2016-4-29 10:06 | 只看该作者
fly448245819 发表于 2016-4-29 08:09
感觉不抗风,轻轻一吹就走
大机和小机都一样 要说抗风 我飞过最大的450 和最小的130 2-4级风130更好飞 5级以上 不管那种飞机都没有人会飞
发表于 2016-4-29 10:50 | 只看该作者
配件方便么?
 楼主| 发表于 2016-4-29 14:13 | 只看该作者
rotorx官网上买 麻烦就TB上配
