查看: 1646|回复: 4
电调中的OPTO,到底是什么英文单词缩写
发表于 2017-1-22 15:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
电调中的OPTO,到底是什么英文单词缩写?
发表于 2017-1-22 17:06 | 只看该作者
optoisolator
发表于 2017-1-22 18:36 | 只看该作者
发表于 2017-1-24 01:28 | 只看该作者
http://www.dronetrest.com/t/what ... our-multirotor/1305
“ESCs without BEC are often referred to as OPTO (optoisolator). All this means that that the part of the ESC that receivers the signal from your flight controller or R/C receiver is isolated from the higher voltage circuit that powers your motors. OPTO ESC's are common on many multirotor setups as your dont always need a BEC as discussed above.”
 楼主| 发表于 2017-1-24 14:09 | 只看该作者
neosunrise 发表于 2017-1-24 01:28
http://www.dronetrest.com/t/what-to-consider-when-buying-a-esc-for-your-multirotor/1305
“ESCs with ...
非常感谢!
