查看: 1241|回复: 2
关于K120和K110的锁尾
发表于 2017-8-21 14:29 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
用的华科尔的DEVO8S控,安装4合一高频头,刷5.0的程序,配置是用的论坛的如下:
name=XK-K100
mixermode=Advanced
[radio]
protocol=S-FHSS
num_channels=8
fixed_id=123456
tx_power=10mW
[channel1]
template=expo_dr
[mixer]
src=AIL
dest=Ch1
scalar=100
curvetype=expo
points=35,35
[mixer]
src=AIL
dest=Ch1
switch=AIL DR1
scalar=70
curvetype=expo
points=35,35
[channel2]
template=expo_dr
[mixer]
src=ELE
dest=Ch2
scalar=100
curvetype=expo
points=35,35
[mixer]
src=ELE
dest=Ch2
switch=AIL DR1
scalar=70
curvetype=expo
points=35,35
[channel3]
safetysw=Virt1
safetyval=-100
template=expo_dr
[mixer]
src=THR
dest=Ch3
curvetype=7point
points=-100,-66,-33,0,33,66,100
[mixer]
src=THR
dest=Ch3
switch=FMODE1
curvetype=7point
points=85,80,80,80,80,80,85
[mixer]
src=THR
dest=Ch3
switch=FMODE2
curvetype=7point
points=100,95,95,95,95,95,100
[channel4]
template=simple
[mixer]
src=RUD
dest=Ch4
[channel5]
template=simple
[mixer]
src=ELE DR0
dest=Ch5
curvetype=expo
points=0,0
[channel6]
scalar=60
template=expo_dr
[mixer]
src=THR
dest=Ch6
curvetype=3point
points=-30,0,100
[mixer]
src=THR
dest=Ch6
switch=FMODE1
curvetype=3point
points=-100,0,100
[mixer]
src=THR
dest=Ch6
switch=FMODE2
curvetype=3point
points=-100,0,100
[virtchan1]
name=T Hold
template=complex
[mixer]
src=Virt1
dest=Virt1
usetrim=0
curvetype=min/max
points=0
[mixer]
src=THR
dest=Virt1
offset=-1
usetrim=0
muxtype=add
[mixer]
src=AIL
dest=Virt1
switch=RUD DR1
usetrim=0
curvetype=fixed
[trim1]
src=LEFT_V
pos=TRIMLV+
neg=TRIMLV-
[trim2]
src=RIGHT_V
pos=TRIMRV+
neg=TRIMRV-
[trim3]
src=LEFT_H
pos=TRIMLH+
neg=TRIMLH-
[trim4]
src=RIGHT_H
pos=TRIMRH+
neg=TRIMRH-
[timer1]
type=countdown
src=!Virt1
time=260
[timer2]
type=permanent
src=!Virt1
val=80
[datalog]
switch=None
rate=1 sec
[safety]
Auto=min
[gui-128x64]
V-trim=59,10,1
H-trim=5,59,3
V-trim=65,10,2
H-trim=74,59,4
Small-box=2,22,Ch3
Small-box=2,31,Timer1
Small-box=2,40,Timer2
Model=75,20
Battery=102,1
Toggle=4,10,0,3,0,RUD DR
Toggle=13,10,0,5,0,ELE DR
Toggle=22,10,0,4,0,AIL DR
Toggle=31,10,0,0,0,None
Toggle=40,10,0,0,0,None
TxPower=102,7
quickpage1=Telemetry monitor
        锁尾感觉很一般,120稍微好点,控上怎么找不到锁尾感度的地方,请教大家怎样调试锁尾感度。
发表于 2017-8-21 16:51 | 只看该作者
没法调吧。。锁尾不好换电机。
发表于 2017-8-21 17:14 | 只看该作者
5通道应该是
