查看: 2512|回复: 5
大疆MATRICE 200 V2非官宣实物照片
发表于 2019-2-22 01:46 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
大疆刚刚发布的新机型,感兴趣的就先来看刚刚出炉的实物照片吧!
MATRICE 200 SERIES V2
BUILT TO ENDURE.
ENGINEERED TO ADAPT.
The ultimate platform for aerial productivity combines a rugged design and simple customizability to work as a solution for a variety of industrial applications. Improvements to the M200 Series V2 enhance intelligent control systems, flight performance, and add flight safety and data security features.
Icons:
IP43
OcuSync 2.0
TimeSync
Anti-Collision Beacon
Versatile Platform
Matrice 200 V2
Reliably Tough
FPV Camera
Anti-collision Beacon
Discreet Mode
Mobile SDK Compatibility
DJI SkyPort Compatibility
TimeSync
Matrice 210 V2
Adaptability on the Go
All M200 V2 Features
Onboard SDK Compatibility
Power Onboard Devices
Matrice 210 RTK V2
Powerful Precision
All M210 V2 Features
Built-in High-performance RTK Modules
D-RTK 2 Mobile Station Compatibility
Compatible Payloads
ZENMUSE XT2, ZENMUSE X5S, ZENMUSE X7, ZENMUSE Z30, ZENMUSE X4S, ZENMUSE XT, Third Party Payloads
Intelligent Controls
Transmission
Enjoy a more reliable and stable flight with the new OcuSync 2.0 system, which supports automatic dual frequency band switching and extends flight range to up to 8km.
Calibration
When multiple payloads or third-party payloads are installed, users can readjust the drone’s center of gravity in the DJI Pilot app, enhancing flight performance and safety.
Data Accuracy
The TimeSync system continuously aligns the flight controller, camera, GPS module, RTK module for the M210 RTK V2, as well as payloads or onboard accessories. The position data is fixed to the center of the CMOS for precise geotagging when using DJI payloads.
Discreet Mode
When the situation calls for unobtrusive drone operations, especially at night, all lights can be completely turned off in the DJI Pilot app.
Safe and Secure
1. AES-256 Encryption
The AES-256 encryption keeps your data transmission secure so you can be sure that your critical information stays safe.
2. Obstacle Avoidance
A robust FlightAutonomy system with front, bottom and upper sensors detects and avoids obstacles while enabling precision hovering so that you can fly with confidence.
3. Anti-Collision Beacon
Equipped with new top and bottom anti-collision beacons, the V2 drones are visible at night or in lowlight conditions, making operation in less than ideal conditions safer.
4. DJI AirSense
With a built-in ADS-B receiver, the DJI AirSense technology enhances airspace safety by automatically providing the operator with real-time information about nearby airplanes and helicopters.
Always Ready
1-Click Upgrade
The remote controller, drone, payloads, RTK module, and RTK base station can now be upgraded simultaneously with just 1-click in DJI Pilot or DJI Assistant 2.
Dual-Battery System
The self-heating battery system allows a maximum flight time of 38 minutes and an operating temperature range of -20 to 50°C.
Optional Accessories to Enhance Performance
Manifold 2
Turn your vision into reality using DJI’s onboard computer – the Manifold 2. Leverage its flexibility and expandability to build customized drone solutions and bring your robotics operations to the edge.
Coming Soon
D-RTK 2 Mobile Station For Matrice Series
Gain improved relative accuracy with centimeter-level precision positioning data using the D-RTK 2 Mobile Station, which supports all major global satellite navigation systems and provides real-time differential corrections.
Learn More
Upward Gimbal Connector
Connect any compatible payload above your M210 V2 and M210 RTK V2 drones using the upward gimbal connector to capture data from a different aerial perspective.
Contact Us
External GPS Module
Enhance positioning accuracy by using an external GPS module, especially when using an upward gimbal on the M210 V2, or when attaching onboard devices or payloads.
Supported Payloads:
XT2
Dual-sensor camera with a 4K visual sensor and thermal imaging with <50 mK sensitivity
Learn more about XT2
X5S
M 4/3 camera with multiple lens options for the best image.
Learn more about X5S
X7
Super 35 sensor camera with multiple lens options for cinema-quality image.
Learn more about X7
Z30
30x optical zoom camera ideal for detailed inspections.
Learn more about Z30
X4S
Shoot 20 MP stills with a leaf shutter, ideal for surveying.
Learn more about X4S
XT
Precise and rapid aerial thermal imaging with <50 mK sensitivity.
Learn more about XT
Build imaging or robotic tools for your specific workflow needs using PSDK.
Learn more about PSDK
https://www.dji.com/mobile/matrice-200-series-v2
 楼主| 发表于 2019-2-22 09:46 | 只看该作者
发表于 2019-2-22 10:18 | 只看该作者
好东西
发表于 2019-2-22 10:51 | 只看该作者
不是之前发布过的工业级飞行器吗?
发表于 2019-2-28 11:07 | 只看该作者
广告贴也没诚意,一堆英文说明。
发表于 2019-3-13 09:52 | 只看该作者
我不知道,你发英文什么意思,显示高端还是肿么回事、
