可以用3S-6S飞,呵呵
![](http://www.trextuning.com/PICT2499641.jpg) ![](http://www.trextuning.com/PICT2500651.jpg)
Kontronik Jazz 40-6-18 Brushless Electronic Speed Control
Features:
- More features for the advanced pilot
- Different programmable modes for airplanes, helicopters, gliders, gliders, cars, boats, competition level and reversible rotation
- Ultra-low noise suppression BEC circuitry for super-clean radio control
- Measures motor inductance and winding resistance and matches power accordingly
- Custom "partial load capability" for very high efficiency even at reduced throttle
- Frequency adjustable from 8 kHz to ultra-high 32 kHz
- Can be used with sensored or sensorless motors
- EMF brake with 10 brake strength settings
- Audible tones and LED for easy setup
- Can be used with Lithium polymer batteries
- Adjustable Soft Start safety feature
- Anti-drift, temperature, and current overload protection
- Current limiting feature
- Auto Programming Mode for quick and easy setup
- RPM control for governing a helicopter's main rotor speed
- Two year manufacturer limited warranty
Includes: One Jazz 40-6-18 Brushless Electronic Speed Control with instruction manual, three connectors, and three sections of shrink wrap.
Requires: Installing in model and connecting to battery, motor, and receiver
Specifications
- Number of Cells Input: 6-18
- BEC: Yes
- Max Constant Current: 40A
- Max Surge Current: 50A
- Weight: 1.16oz (33g)
- Length: 1.9" (49mm)
- Width: 1" (25mm)
- Thickness: 0.29" (7.5mm)
:em15: 忘记说了,价格大概是$169.95 |
