查看: 1994|回复: 19
老外做的蜘蛛起落架~~很牛哦 !
发表于 2008-4-8 13:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
I am launching a brand new and articulating landing gear brand named "SpiderGear"starting with the Align T-rex 450. This is a direct replacement for the stock gear. I spent considerable time coming up with a functional, durable and visually appealing design and i hope that you all agree. I know there are other flexible landing gear out there, but i decided to come up with something that works and is also more durable than anything out there. I have a few flying buddies that are in the learning process, dealing with hard landings and the broken parts that become of them. The Spider Gear are an assembly consisting of 3 cnc machined main components; an .032 6061 aluminum lower frame stiffener plate that sandwiches between the landing strut and the lower frame, a main landing strut that screws into the stock lower frame plate and 2 articulating arms that pin into the main landing strut. The aluminum skids are included as well. The hardware package includes 2 springs, 4 #2x1/2 screws, 2 stop pins, 2 axle pins, 4 retaining collars, 4 nylon thrust washers and 2 set screws for the landing skids (the skids are retaining only by the rear half of the gear, that way they can articulate upon an angled landing and start absorbing shock before the rest of the heli hits. All parts are powdercoated either super chrome, or silver vein. Custom colors can also be done. All up weight is approximately 3 ounces
Spidergear is designed to reduce the shock load that the helicopter structure receives, by using springs, dampening rate increases the farther the arms are flexed. The stiffener plate distributes the load across the bottom of the frame, further reducing shock loads to any one corner of the airframe.
I am so sure of the durability of this product that, The aluminum strut and arms will be covered with a lifetime replacement warranty.
Since this is a launch of a new product, i'm going to offer a special available here only on helifreak and runryder to jumpstart this exciting new product. For the next 2 weeks, I will sell the complete spidergear which includes the stiffener plate, 2 main struts, 4 arms, 2 skids and all of the necessary hardware for $29.95. I'm so confident in this product that if anyone who purchases a set of spidergear is unhappy with the performance, i will refund the money. I'm doing this special to get some gear out there for review. You will not be disappointed.
Patent papers were received and filed Friday the 4th, they are now in patent pending status and production will begin on Monday April 7th
作        者:sandtrx
原帖地址:http://www.helifreak.com/showthread.php?t=68978
发表于 2008-4-8 14:15 | 只看该作者
发表于 2008-4-8 14:21 | 只看该作者
漂亮!~期待飞越开发!~
发表于 2008-4-8 14:48 | 只看该作者
这才是真正的耐摔脚架
发表于 2008-4-8 14:59 | 只看该作者
不知空中高G力的表现如何。
发表于 2008-4-8 15:14 | 只看该作者
多此一举
不过喜欢DIY可以理解
发表于 2008-4-8 15:26 | 只看该作者
很多炸机不会是垂直向下角度的,其他角度炸下来这个脚架应该死的很惨而且维修成本。。。
DIY的功力确是不错~
发表于 2008-4-8 15:41 | 只看该作者
我想看实际摔机的实验!
发表于 2008-4-8 15:55 | 只看该作者
好像不实用
发表于 2008-4-8 16:42 | 只看该作者
不错!!
发表于 2008-4-8 18:08 | 只看该作者
看了一遍,感觉就象是车的避震一样,给出的质保仅仅是金属件。。。没有说道最关键的弹簧问题(真个才是整体的精华),从图像上看这个弹簧的质量一般。。。
发表于 2008-4-8 18:20 | 只看该作者
油直用这个应该不错,450没必要吧,一副脚架,快两年了
发表于 2008-4-8 20:50 | 只看该作者
初学蛙跳的很有用
发表于 2008-4-8 22:49 | 只看该作者
练熄火降落也有用
发表于 2008-4-9 08:50 | 只看该作者
带缓冲的~:em15:
发表于 2008-4-9 12:07 | 只看该作者
练熄火降落不错
发表于 2008-4-9 12:59 | 只看该作者
带避震器了。
发表于 2008-4-10 21:14 | 只看该作者
初学蛙跳的很有用
发表于 2008-4-10 21:38 | 只看该作者
还是在安装脚架的螺丝上放橡皮圈的方法更好,就算以别的角度落下也不会出问题!走弯路了。
发表于 2008-4-10 22:55 | 只看该作者
喜欢
